Question about Jabra BT150 Wireless Headset
Jabra BT150 My Jabra 150 will not charge can you give me a reason. There is no charging light comes on. Is there a battery in the headset that i can replace.
  • Anonymous May 18, 2009
    same problem
  • Anonymous May 26, 2009
    same problem
The first dude is an idiot! The battery is toast go buy a headset that isn't as old as this Jabra! I also have the issue & no didn't plug it in wrong...it only goes one way! Mine sat for a few years unused & now will not charge...You can get newer headsets pretty cheap! Look around!
Posted on May 28, 2011
  • 26 Answers
Probably, you have the charger inserted backward. The polarity keying is POOR on this model.
Yes, the battery is replaceable, but no it's not easy. And it's probably cheaper to get a new, better model. The wire mounting points on the PCB are TINY, and require some fair skill to work on.
Easier solution, should you want to try is... cut the battery wires right at the battery, and solder those onto the wires from your new battery.
Only recommended if you already have a matching battery, AND you LOVE your jabra, AND you can afford to buy a new one in case you screw yours up.
Instead, invest in a Jabra BT2040 and a 9volt battery(duracell uses 6 AAAA batteries in the case, and the tabs are easy to clip, for "standard" use in this model).
Posted on Jun 01, 2009
SOURCE:
Jabra wave battery suddenly won't charge
The battery may be shot and incapable of charging. The red light could be merely indicating that the charger is working.
Jan 13, 2014 | Jabra Wave Bluetooth Headset
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
I charged the BT350 using the Jabra Charging
I called Jabra Support and they are sending out another unit. The technician indicated that the battery is likely defective and is not field replaceable.
Thank you,
Dec 11, 2009 | Jabra BT350 Bluetooth Headset Headset
I have a jabra bt250. I put into the charger one
A search on here will get the answer I found it once it. is the battery and headset needs to be opened and 'jumpstarted' it is non replaceable though.
Sep 24, 2009 | Jabra BT250 Consumer Headset
New jabra 350 can't be charged
right out of the box i had the light flicker on me too. if you don't have warranty or receipt like i did try this. i'm not responsible if it doesn't work after!
peel off the blue part of plastic that has jabra on it. take a screwdriver and unscrew the star screws. take the cover off. using some wires, briefly connect a battery (i used a wireless drill battery) to the leads of the bluetooth battery. you'll see a spark.
now my thing is charging for the first time
May 24, 2008 | Jabra BT350 Bluetooth Headset Headset
This is what I did:
1. open the headset by following these steps:
http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/
2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v.
3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine.
4. Reassemble and hope your headset is back to business.
May 10, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra bt 250v not charging or cannot use headset.
Try this link to help you on this site it is a battery problem
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Sep 28, 2007 | Jabra BT250 Consumer Headset
Unit won't charge and I get no lights
I have the same problem. it's due to a faulty pover-cell inside the headset. i have also read that the charger can be inserted the wrong way, this would in turn kill the battery by giving it a reverse charge.(not sure about that) as i tried this after finding the unit defective and it will only plug in one way.. the only suggestion that i can give is contact Jabra directly. iv'e read that they will replace any headset in this range for free, here is the address for their site. http://www.jabra.com/Sites/Jabra/UK-UK/pages/Contact.aspx Hope this helps.
Sep 14, 2007 | Jabra BT500 Wireless Headset
Jabra BT150 Wireless Headset Logo
779 people viewed this question
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
