Ovens Logo
Paul Rogers Posted on Nov 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After power outage, digital clock on St. George double wall oven model #deo5 needs resetting. I have no manual so no idea how to do
Joe Richardson
Level 2:
New Friend:
  • Expert 122 Answers
  • Posted on Nov 03, 2013
Joe Richardson
Expert
Level 2:
New Friend:
Answers
122
Questions
0
Helped
43019
Points
429
Can't find your model # but maybe this can help:
St. George Oven Manuals
5 Related Answers
Anonymous
  • 110 Answers
  • Posted on Apr 03, 2008
SOURCE: Cannot set clock Model RBS245PDB2
you need to replace the clock timer board..
Anonymous
  • Posted on Oct 04, 2008
SOURCE: Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Anonymous
  • Posted on Jun 22, 2009
SOURCE: instruction manual for Westinghouse wall oven
Obtained info from retailer
Anonymous
  • Posted on Jul 11, 2009
SOURCE: chef classic wall oven with digital clock change time?
Press the TIMER button (the leftmost one with a little bell icon) and the "cooking" button (the one next to it with a "hot saucepan" icon) briefly at the same time. Within four seconds start changing the time with the + or - buttons. When you have the correct time just leave it and it will leave time setting mode four seconds after the last button press.
Anonymous
  • Posted on Oct 03, 2010
SOURCE: turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
12helpful
Turn off the timer on an old imperial st george
Jan 23, 2010 • Ovens
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 • Ovens
1helpful
2answers
We had a power outage and the oven will not work, after shutting off the power the panel lit up with all 8888s and will not work
Forgive me for saying this, turn the unit off wait 30seconds, then turn on again (this sometimes works)
There is a very good possibility you have suffered a power surge which has damaged your electronics unit. Please check your manual to see if there is a reset button on the display (this sometimes reolves it).
If there is no way to reset, then you will need to replace the displat/circuit board, this is quite fiddly and i would recommend you call in an appliance expert.
I hope this helps.
1helpful
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 • Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
