Refrigerators Logo
Willy Pimentel Posted on Nov 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
COMPRESOR IS NOT TURNING ON ON MY FRIGIDAIRE FRS23LH5D WHAT CAN I DO?
  • Willy Pimentel
    Willy Pimentel Nov 03, 2013
    Thanks.... Is there a tutorial anywhere how to do that??
PRIMOAPPLIAN
Level 3:
  • Master 401 Answers
  • Posted on Nov 03, 2013
PRIMOAPPLIAN
Master
Level 3:
Answers
401
Questions
0
Helped
106230
Points
1126
IF ITS CLICKING ON AND OFF YOU MAY WANT TO CHANGE THE RELAY/OVERLOAD. IF THEN IT DOES NOT START THE COMPRESSOR IS BAD..GOOD LUCK!@
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
mikadot
Level 3:
  • Master 2,113 Answers
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
465756
Points
5959
Just a thought, if your defrost timer stopped running or is stuck in off position your compressor won't run. I would check the defrost timer first, turn it with a screwdriver till you hear the compressor turn on. If that is it replace the timer.
2answers
Gimme an idea -- side by side, fridge side not cooling. thanks
check for compresor operation. relay in compresor can fail at times
Compresor is not running - a yelow and right
your power contactor relay on the compressor body is defective
Everthing sunddenly thawed out how come? whats the fix can i do it my self
If you heard the compresor running and it's not cooling ,probably is out of refrigerant(freon) ,but ifthere's power in the outlet and the compresor isn't working and is hot to the touch ,could be the relay or the compresor went bad ,also if there's power but the compresor is cold it could be the thermostat is open ( you can check it by putting a jumper in the thermostat wires).
2helpful
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Jul 31, 2009 • Freezers
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
No cooling,compressor comes on and shuts off quickly
All refrigerators compresors have a relay and a overload thermal protector ,both are located on the side of the compresor behind a black plastic cover atached to the compresor with a metal clip(or just the cover snaps in on the compresor).Unplugged the fridge ,pullout the cover and you'll see the relay and the overload replaced them (no more than $30).If this doesn't solve the problem you have a bad compresor, wich is a much more expensive job.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
