My Honeywell F50F1073 will not pickup any dust any more. Do I have to replace, replace with media filters or is there a fix?
The presence
of
“white dust” is actually an indicator that your Electronic Air Cleaner
is
working properly. The Electronic Air Cleaner can only filter the
particles that
are passing through your system’s duct work. The staining particulate is
generally lighter, and more able to be drawn through the return
registers in
your home, leaving the heavier, non-staining particulate behind. This
heavier,
non-staining particulate settles out of the air and is left behind on
your
furniture: because it is more visible, it may appear as though there is
actually more dust in your home than there was prior to installing the
air
cleaner. To ensure that more particulate is able to reach the Electronic
Air
Cleaner to be filtered, you should make sure that the return registers
are
clean and not blocked by furniture.
is the light illuminated when the power is switched on and the furnace fan is also on?
