Recently purchased Dell Vista Home Premium. Cannot get my "Swift Classics CARD GAMES for Windows to install. Had it installed in Dell Windows XP and it worked just fine.
you will need to check system requirements for the game as it may not be able to operate under windows vista especially if you have the 64-bit version of vistayou will need to check system requirements for the game as it may not be able to operate under windows vista especially if you have the 64-bit version of vista
You can't post conmments that contain an email address.
It's probably an issue with Vista, right click on the icon, go to properties, run as administrator, and run in compatability mode for XP. If this doesn't fix the problem, try contacting the software manufacturer.
2. Run Windows XP Mode with Virtual PC. This one more complicated because it involves installs and running a virtual system. Use only if you feel comfortable with instructions. http://www.microsoft.com/windows/virtual-pc/download.aspx
Lower bit-rate should not be a restriction on use.
For programs one can use the compatibility mode, both the installers and executable files. Click right for the context menu and don't go to Compatibity but Advanced. Choose the Tab Compatibility and select the Windows version that seems to be fit from the list.
The program can not be rewritten. For DOS there are programs like DosBox where you can drag old DOS programs onto. Windows can be installed in separate partitions, the older versions first. Then accessed by Windows boot menu. Another idea is to make a virtual disk and install the old Windows version from there.
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
The product key on the label on the bottom of the laptop will only work for the version of Windows that was installed on that laptop.
You can purchase an upgrade Windows Vista Ultimate and to use in conjunction with the existing Vista Home Premium.
If you installed Vista from a box that you recently purchased then the key is on a yellow label on the back of the pull out section. If your PC originally had Vista and the label was on the bottom of the machine then Microsoft should it with your registration.
Yo u have 2 slots in u r machine I am sending u details information of updradation in ur machine :
frequency of ram should be
667 MHz Dual Channel DDR2 SD RAM
option 1. A system ready for the next generation of applications and games 3 or 4GB1 Dual Channel2 DDR2 SDRAM
2. A system capable of handling Windows Vista® Aero as well as today’s latest games. 2GB Dual Channel2 DDR2 SDRAM 3.
Basic performance for the Windows Vista® AeroTM interface (PCs purchased with Windows Vista Home Premium and less than 1GB of memory will NOT be capable of running Aero). 1GB Dual Channel2 DDR2 SDRAM 4.
Basic performance, lowest initial cost (Windows Vista® Home Basic) 512MB Dual Channel2 DDR2 SDRAM
