Question about Casio FX9750GII Graphic Calculator
I keep getting a negative number when i try to do tan40
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
The tangent of 40 radians is a negative number.
Posted on Jun 15, 2014
SOURCE:
What is a negative numbers
a negative number is any number less than zero. for example if you subtract 4 form 3 you get -1 which is negative one.
Nov 17, 2014 | Office Equipment & Supplies
Is it better to keep negatives in a sleeve or can I keep them the way that they came back from CVS?
It is much better to get sleeves to keep your negatives in, in order to use them you have to keep them clean and dry. You might also want to look into digitally scanning your negatives to better preseve them.
Sep 23, 2013 | Photography
How to fix error mesage on TI-30Xa. Every time I press LOG an error sign comes up. how do i fix this?
To take the log of a number, enter the number then press the LOG button, then the =. To take the log of a negative number, enter the negative number using the +/- key just to the right of the decimal point. To calculate the negative of a log, calculate the log and then negate it using +/-. To calculate the antilog (inverse logarithm), press 2nd then LOG.
Bear in mind that LOG is the common (base-10) logarithm. For the natural (base-e) logarithm, use the LN key to its right.
Nov 07, 2011 | Texas Instruments TI-30XA Calculator
I am having issues performing a simple function on my TI-30XS calculator. when I square a negative number - I get a negative number as opposed to a positive number?? example -3 - which I specify the...
You're not calculating the square of a negative number, you're calculating the negative of a square. You need to use parenthesis to indicate the square of a negative number.
You're calculating -(3^2), not (-3)^2.
To calculate the latter: ( (-) 3 ) x^2 =
Dec 05, 2010 | Texas Instruments TI-30XA Calculator
When i square a negative, i get a negative answer, how do i fix it so it gives me the positive number?
Actually, you're negating a square, not squaring a negative. When you put in -x^2, it's getting calculated as -(x^2). In order to square a negative number, use parentheses and calculate it as (-x)^2.
Also, make sure you're using the +- key to the right of th decimal point instead of the - key when entering the negative number.
Oct 01, 2010 | Texas Instruments TI-30X-IISTK Scientific...
Negative amount
Sounds like one department is selling / transferring from another department.. You should see offsetting numbers in the other departments to track it down. Just look for positive entries in other departments that match the negative entries, and verify with date & time stamp and item / SKU number. May be a programming error.
Nov 20, 2008 | Casio Parts Cash Register PC Desktop
Negative answer when squaring a neg number
You must put all negative numbers in Parenthesis otherwise your calculator is not squaring the negative .
Apr 20, 2008 | Texas Instruments TI-85 Calculator
Casio FX9750GII Graphic Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
