Question about Lexmark T642 Laser Printer
T642 wont recognize tray 2 or duplex
On T642 lexmark the unit does not recognize tray 2 or the duplex unit installed. Setup only shows tray 1 and mp as tray options. It is not the tray 2 or the duplex unit because another printer works with them. Has to be something with the printer.
  • Anonymous May 11, 2010
    There is a self docking connector on the bottom of the printer that connects to a similar connector on the duplex unit. Check that these connectors are not damaged by lifting the printer off the duplexer and inspecting visually . You can try removing the duplex unit altogether and just install tray 2 below the printer with no duplex unit at all to see if the printer sees tray 2. If it does see it
    then the problem is in the duplex unit. If the printer can't see the duplexer it also wont see tray 2 which is below it. Simply replugging the units might fix it too so give that a try.
  • 15 Answers
You need to be sure you add the duplex unit and tray unit in the windows driver. The "device" tab will allow you to add the duplex and tray to the
printer.
Posted on Aug 18, 2009
  • sm2u4u
    sm2u4u Feb 14, 2013
    I have a question about setting up a lexmark t640 at motorcycle dealership. This is very important as this client could potentially further my IT repair business. Could you contact me directly by email mnicholsjr@email.itt-tech.edu?
SOURCE:
I have a Lexmark T634N printer. I have problem with it recognizing the 2nd tray and the Duplexer. I have replace the motherboard, replace the connector on the printer, updated the software on the printer...
Hi
You need to be sure that you have added the duplex unit and tray unit in the windows driver. The "device" tab will allow you to add the duplex and tray to the printer.Also there is a self-docking connector on the bottom of the printer that connects to a similar connector on the duplex unit. Check that these connectors are not damaged by lifting the printer off the duplexer and inspecting visually . You can try removing the duplex unit altogether and just install tray 2 below the printer with no duplex unit at all to see if the printer sees tray 2. If it does see it then the problem is in the duplex unit. If the printer can't see the duplexer it also wont see tray 2 which is below it. Simply re-plugging the units might fix it too so give that a try.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Lexmark T634 Laser Printer
My lexmark X832e is asking to chnage MP Feeder Folio. What should I do.
If you disable the MP feature in settings that'll fix it or change the print priority to tray 1.
Dec 03, 2010 | Lexmark T642 Laser Printer
How do i remove the duplex?
Here's an article on How to Install a Duplex Option on a Lexmark T64x Series Printer. Just click on this link: http://bit.ly/94TYQc. This is just to give you an idea on how the duplex option is installed. The duplex unit attaches under the printer, below the standard tray (tray 1) and above any option drawers (trays 2, 3, etc). Removing it is just a matter of lifting up the printer from the duplex option and then lifting up duplex unit removing it from the option drawers, if you have any.
Aug 05, 2010 | Lexmark T640 Laser Printer
It keeps wanting manual feed paper instead of
There is usually no reset from the machine it is in your printer properties. Open the properties and set it to the tray you want it to feed from and usually there is a apply button try that.
Cheers
Al
Sep 11, 2009 | Lexmark T640, T642, T644 500-Sheet Duplex...
Lexmark T642 - I have plain white paper in tray 1 and yellow plain paper in the mp feeder tray. When I choose to print to the mp feeder tray the printer beeps to be loaded with paper but the paper is...
Make sure you have selected the multi purpose feeder (front of the printer) in the driver, not the Manual Feeder.
The manual feeder will prompt for paper on each page. All you have to do is to press the "Go" button.
Jun 03, 2009 | Lexmark T642 Laser Printer
Our printer says load MP feeder. We can't get it to print. Please
The front of the printer is a door that opens this is the MP feeder. Load paper in it and the unit should print. Someone likely sent a job requesting that tray.
for more help see.
http://www.lexmark.com/publications/pdfs/t640/eng/ug.pdf
Hope this helps
Mar 23, 2009 | Lexmark T642 Laser Printer
Lexmark t642 load mp feeder with letter
The reason that your printer is asking you to load paper into the MPF is that it doesn't think it has that size paper in tray 1 or 2. Make sure that the green paper guide in the paper tray that you want to print from is latched in the correct position. This guide tells the printer what size paper is in the tray. If you have it even slightly out of position you'll get this message.
Mar 11, 2009 | Lexmark T642 Laser Printer
Printer problem
Check your paper configuration. Make sure Tray 1 is configured for Plain paper and is showing the right paper size. If it is configured for anything other than Plain Paper, most of your jobs will not print. Also, if the size says something like Univseral, then the printer is not touch that tray unless your print job also specifies Univeral as the size. If is does say Universal, check the paper guide in the tray and make sure it is pointing exactly at the paper size you are using
Dec 12, 2008 | Lexmark T642 Laser Printer
PJL
1- set tray 1 either to paper size letter or any
then paper type to ANY
2- set tray 2 to Letter and Plain
3- go to file - print - right click on printer- properties- device settings make sure you have the properties correct. ( letter size, any options must be listed here, duplex, stapler etc.. and set to on
Apr 22, 2008 | Lexmark T642 Laser Printer
Lexmark T642 Laser Printer Logo
2,561 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
