I HAVE KOHLER K4436AA AND WE ARE HAVING PROBLEM FLUSHING ALWAYS SEEM THAT ITS STUFFED UP AND ITS NOT WILL NOT FLUSH
SOURCE: Kohler Cimmaron Toilet Flush
You might want to check the flush cylinder, to see if it has water in it. It has to be water free, that way the air in it, lets it go down easier, during fill up.
SOURCE: Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
SOURCE: Running toilet
Mine does that also, here's what I found.; I am on a well and occasionaly sand gets caught in the valve thingy... Take the tank lid off, turn the arm that attaches to the float assy. 1/4 turn towards the back of the tank and take it out. Rinse off the gasket and pin as well as inside the hole. Reassemble and it should solve your problem.
SOURCE: kohler lowboy toilet seat does not have bolts underneath
I have the same low boy where the bolts are inside the hollow body of the toilet. I called Kohler customer service and was told to use brute force to yank the toilet seat out. My husband suggested using a saw to cut the bolt but he hasn't done it yet. He wants to replace all our Kohler low boys which constantly leak becos of poor design of handle and flapper. The handle pulls the flapper slightly to the side when you flush. And the flapper lip being a tiny bit too small, if it doesn't sit just right, the toilet leaks. We've replaced one already with a Toto and love it. Too bad that Kohler isn't trying to fix the problem as I see many many online posts with the same problem and recommendation to replace the Kohler with Toto or somethng else.
