Page 128 of the manual says:
Start the computer to which Nikon Transfer was installed.
So before you can transfer pictures to a computer you have to install software. If the software was not in the box with the camera, I'm sure you can get it for free with Nikon.
I use ViewNX2 from Nikon, and it was and still is free. You can transfer and manage the pictures on your PC. Just visit the Nikon website for the apropriate software to your camera.
SOURCE: How do I transfer pictures onto the memory card?
You should be able to transfer the pictures if it has built in memory. then transfer it to memory card the same way you'd take them off
SOURCE: Nikon Coolpix 4100 - transfer pictures to memory card
The easiest way is to transfer pics from the camera memory to you pc/notebook memory and then copy them to the the memory card thereafter with the help of a memory card reader.
SOURCE: Internal Memory to Memory Card
This was a pain for me to figure out. I too had the same problem. This may not be the RIGHT way, but it is how I did it.
First, copy everything you want off the memory card and then insert it into the camera. Format the card.
Then, take a single picture.
Now, with the camera on, hit the playback button to view the picture you just took.
Press the MENU button, and scroll through the menu to the very last entry, which should be COPY.
Press OK, and then you can select to copy from INternal to memory card, or memory card to INternal (note, IN means internal in the menu). You, of course, want internal to memory card, so select it if not already done so, and press okay.
That's all there is too it! I recommend erasing all images from the internal memory once you're done so you don't get confused later if you see images on there again.
Good luck! Ray - www.desertdawg.com
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom. Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
SOURCE: Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
I'm glad to provide the instructions to transfer images from the Camera to the Computer. Once you connect the Camera to the computer, you will get
the Camera as a removable drive under My Computer. You can open the removable
drive to see the pictures stored in the Camera/Memory Card.
If the Operating System installed in your Computer still
needs a driver, you may use the Memory Card slot on the Computer to transfer
the pictures. Please follow the steps to transfer pictures using Memory Card
Reader in the Computer:
Remove the Memory Card from the Camera.
Insert it in the Memory Card slot in the Computer.
Open the pop up window or find out the removable drive under
My Computer.
Copy the required files to a folder in the Computer.
Note : Most of the Notebooks comes with its own Memory Card
Slot. If it does not, you may get one from the market without much spending.
Thanks for understanding.
Please let me know if you need further assistance.
Note: When the camera is connected to a computer using the USB cable with a
memory\picture card in the memory\picture card slot, the computer will
only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
I'm sorry for the difficulties you're
experiencing in transferring images from the Camera to the Computer. Once
you connect the Camera to the computer, you will get the Camera as a removable
drive under My Computer. You can open the removable drive to see the pictures
If the
Operating System installed in your Computer still needs a driver, you may use
the Memory Card slot on the Computer to transfer the pictures. Please follow
the steps to transfer pictures using Memory Card Reader in the Computer:
- Remove the Memory Card from the
Camera.
- Insert it in the Memory Card slot in
the Computer.
- Open the pop up window or find out the
- Copy the required files to a folder in
the Computer.
DCIM
folder contains the images.
Note :
Most of the Notebooks comes with its own Memory Card Slot. If it does not, you
Thanks
for understanding.
Please
Most of the Still cameras do not require driver or software
to transfer images now a days.
My Computer.
I'm glad to assist you in providing the instructions to transfer images from the Camera to the Computer. Most of the Still cameras do not require driver or software
My Computer.
