SOURCE: Power Supply/Video on/off problem
hi, seems to be a problem design, you can check the users review on: http://reviews.digitaltrends.com/review1430.html options 1,5 even 6 is ok. sorry.
SOURCE: Plugged computer back in after move and won't start. green light in mb on.
pls try change the power cable if it works then check your power pack if the FAN doesn't roll that means you have to change the power pack thanks. [email protected]
SOURCE: Mac Ibook Power supply problem
On Mac iBooks the orange light comes on when it charges the battery. Once the battery is charged it turns green. Im guessing the other powersupply was aftermarket or broken. EIther way, if it starts out green - recognizes the battery isnt full - turns orange for a while - then turns green when the battery is full, then the computer and powersupply are working perfectly. Enjoy your iBook!
Actually, there is nothing you can do with the hard drive. If its shorting out the power supply when its pugged in then it is defective. However, most hard drives carry a 3 year warranty from the manufacture. If the drive is younger then 3 years old, I would call the manufacture and get it repaired or replace. Hope this helps . . .
SOURCE: My WD external 500G hard
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
