SOURCE: Burner ignites and goes out (Goodman Gas-fired furnace)
The problem you have is water in the exhaust pipe.
Check to see if the pipe has sagged anywhere or if there is a trap in the line.
If you hear gurgling then it is definetly water....
Some times can be hard to find, even a pipe 1/4 full will cause problems. They are very sensitive to flue problems.
Make sure that the flue pipe either runs back to the furnace or out to the outside, a continuos slope either way witha high spot in the middle.
Also check the bottom drain of the blower if it has one, have had them plug and trap water also..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
SOURCE: Goodman furnace model #GPO 125_4 REV 8 Installed 6/2/2002
Have you measured the temperature in the suppy plenum? Should be 140 to 160 max. If hotter, you have a blockage in the ductwork or vents closed. If within spec, bad circuit board.
SOURCE: Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
SOURCE: Main burners don't come on, though the ignitor goes bright
you should hear a click ,its the valve opening ? of check to see if the air fiter is clean ,
