When the power button blinks do you hear the laptop fans run on full speed? If that happens its because your laptop is overheating and is trying to cool down. It will not turn on until it cools down to protect from damage due to heat.
Use your laptop on a hard surface and dont block its vents with anything. If you want to use it on bed keep it on a laptop cooler or a thick book to allow ventilation.
If laptop doesnt turn on at all, the motherboard might be damaged. Take it to repair shop and check whats wrong.
SOURCE: Compaq R3000
r u mention for battery light?if is it true,then the light is blinking because of your laptop want to make sure the power supply charge that battery.if it is in charging condition,the light on.but if the light goes off,that mean, the battery is already full.
But when u use adaptor without battery, the light will goes off because no charging session is in progress which has same behaviour with battery full(during battery full,no charging session occur)
SOURCE: necesito manual de reparacion y
Aqui esta el manual de mantenimiento. Esta en 5 partes que comienzan de 0 a 4. Tiene que descargar todas las partes, el doble clic en el cero de parte. Combinara todas las partes en un PDF. Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendacion para mi respuesta. Gracias, Jose
http://www.eserviceinfo.com/downloadsm/9115/COMPAQ_Compaq%20Presario%20Widescreen%20Notebook%20PC%20X1000.html
Attention! This manual is multipart. Download all, before decompressing
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
it goes on and off it never turns on so ill take it to a shop. thank you. Ps you no were i can buy a motherboard online
Ebay. Make sure you search for the proper model number of your laptop.
