RCA F27669 TV Logo
Posted on Oct 01, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCA 27V412T my tv started turning itself on and changing the channels by itself
Anonymous
Level 3:
  • Master 790 Answers
  • Posted on Oct 01, 2007
Anonymous
Master
Level 3:
Answers
790
Questions
6
Helped
225243
Points
1965
Ok! change all tact switches! your tact switch has abnormal resistance! thats why your tv is changing system!
My RCA 27V412T TV turns the screen red
Can you see a picture at all or is it completely bright red? Is there sound?
Im looking for the manual for my RCA 27V412T
You can view or save your manual from this site to view in PDF or print if so desried.
http://tv.manualsonline.com/manuals/mfg/rca/27v412t.html?idRes=11396722
1helpful
Why does my RCA model# 27V412T turn on and off by itself? It's does not stay on long enough for me to reprogram the remote.
Hi There,
Sounds like your Startup Relay is intermittent. Contacts are closing (tv on) then dropping out (tv off). Worn or burned contacts do not make a good connection when they close and start to burn and overheat causing the contacts to open. When they cool down they may make contact again for a very short period. You need to replace the Start up relay. I hope this helps and thank you for using FixYa!
Sudden channel changing,flipping off and on and channel searching
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
RCA 27V412T
check your tv's power cable inside the tv. make sure its not frayed. also take the batteries out the remote, it could be turning off the tv.
TV TURNS ON BY IT SELF AND CHANGES CHANNELS AND FPA LOCK IS ON
the problem is there is engaged button there..only technician can do the job by replacing the button that is always engage.
RCA 27V412T
I repair these for a living and usually this is caused by the "tact switches" (buttons essentially) on the main pcb. This can be fixed easily by someone who is familiar with working with soldering small parts by changing the switches. The problem is most service shops must charge $60-$100 for bench time on a repair like this which is hard to spend with the replacement cost being so low on this product.
TV turns on by itself
Just change all the buttom (switches) including: volume, channal, power, and menu buttom. That is the only problem
Turns off/ on by itself model 27v412t
well my tv was doing the same thing my prob was the buton bord.the ezyest way to check it was to take the back off and find the wires that come from the boton bord the plug the tv in and turn the tv on wile its on unplug the boton bord wires if the tv stays on that is probly your prob the bord dont cost much I found a site on here that has them for under $5.remember to be carefull when checking it out tv car be very dangerus.I found that if I beat on my buton bord alittel it would work for awile hope this helps
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
