Telenor sim card is not showing contacts in nokia 101,. when i open sim menu, it says "Sim card busy". but sending msgs n making calls is fine.. when i put this sim in nokia N70, it shows sim contacts and also sim menu.. plz help cox i mostly use this sim in nokia 101
SOURCE: Nokia N70 Insert sim card problem.......
i can solve this
if you want to format your memory follow this:
menu>tools>memory>then press options>from the list select format mem.card.
SOURCE: Nokia N70
there is an option in settings menu that say restore factory settings.Do that and the code is 12345 exept if you change it
SOURCE: How to insert SIM in Nokia N70
Take off the back battery civer, remove battery the sim slot should be under battery on most nokia models if you see no sim slot then your model is not GPRS its CDMA and requires a CDMA provider so check and make sure, Even tho you model may have one or the other there are two form factors to your model phone so this all depends on the formfactor and what system it was designed for. But like i said if you see no sim slot chances are its CDMA.
Best of luck to your please do rante and leave feedback ether way if you have any questions please ask, thank for using fixya.com
Btw, Iām available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: I HAVE NOKIA 5530 XM. IT CANNOTSEND TEXT MESSAGES.
nice noon...you need go to cellphone repair shop anf try to reprogram or master reset your phone,,i think the problem of your phone is software..good luck....
SOURCE: nokia 95 8gb china , showing invalid sim or sim
i have a china made mobile n8 but after inserted it shows invalid sim what's the solution of this problem
