DISH Network 311 DTV Receiver Logo
A
Anonymous Posted on Nov 01, 2013
Signal code 31145 - DISH Network 311 DTV Receiver
How do I fix code 13 engine speed sensor Above 1000 rpm
Clearing the codes is simple that is done by removing the fuse of the EFI from junction box 2 for 10 seconds. Make sure to remove the jumper wire and switch the key off before clearing the codes.
Here are some common Lexus vehicles 1990-1995 codes:
Code 12 and Code 13 Rpm signal circuit fault
Code 14 Igniter signal circuit fault
Code 16 ECT control signal fault
Code 21 and Code 28 Main oxygen sensor fault (for ES300; SC300 & GS300 models)
Code 22 Coolant temperature circuit fault
Code 24 Intake temperature sensor circuit fault
Code 25 and Code 26 Air fuel ratio fault (for ES300 & SC300 models)
Code 27 Sub-oxygen sensor circuit fault (for ES300 CA & GS300 models)
Code 31 Low airflow meter voltage (for ES300 and GS300 models)
Code 32 High airflow meter voltage (for ES300 model)
Code 35 Barometric pressure sensor circuit fault (for GS300 & SC300 models)
Code 41 and Code 47 Throttle position sensor circuit fault
Code 42 Vehicle speed sensor circuit fault
Code 43 Starter signal
Code 51 Switch condition signal fault (for ES300; GS300 & SC300 models)
Code 52 Code 52 and Code 55 Knock sensor circuit fault
Code 71 EGR system circuit fault (for ES300; GS300 & SC300 models)
Code 78 Fuel pump control circuit fault (for GS300 & SC300 models)
2002 hd 1400 has a #2 code showing up will not clear
If you've got that Engine light coming On for 4 seconds, Off 4 seconds then On 8 seconds then out, its historic. (there WAS a problem that has now cleared)
If its On 4, Off 4 then remains On its a 'current' code.
I never heard of a #2 code.....they are read as a two digit code.
Here's one method some use to clear all codes:
Disarm alarm if so equipped.
Run/Off switch to OFF
Ignition Key: ON,OFF,ON,OFF,ON (and leave ON)
Press LEFT turn signal switch TWICE. Wait for 1 or 2 flashes..
Press RIGHT turn signal switch ONCE => turn signal will flash 1 time
Press RIGHT turn signal switch ONCE => turn signal flashes 2 times
Press RIGHT turn Signal switch ONCE => turn signals flash 3 times
Press LEFT turn signal switch ONCE. TROUBLE CODES WILL NOW BE DISPLAYED
TO CLEAR ANY CODES,,,=> PRESS & HOLD LEFT signal switch for 5 seconds. => turn
signal will now flash twice to confirm memory is clear.
Turn ignition OFF.
2answers
Truck will be running fine, then all of a sudden it will completely shut off. After we wait a few minutes and pump the clutch and make sure it is all the way to the floor it will start, sometimes. S
You need the engine computer scanned for fault codes, i thank you have an ignition control problem like a module or distributor pickup coil issue. These parts whenthey fail should leave fault cdes so get them read.
Next, the check engine light will pause shortly followed by the second digit of the trouble code. For example if the check engine light blinks once and pauses followed by six blinks the trouble code number would be 16. If no code is present the check engine light will stay one constantly. To restart code gathering turn the ignition key to the "off" position, wait three minutes and turn the ignition key back "on" again without starting the engine. Remove the jumper wire once code gathering is complete. To clear code after the repairs have been made remove the negative battery cable for one minute and reconnect.
Toyota Diagnostic Connector
Toyota Code Definition Table
Code 11 Momentary interruption in power supply to ECU (electronic control unit or computer) up to 1991
Code 12 Engine revolution signal missing Code 13 Rpm signal to ecu missing above 1000 rpm
Code 14 Igniter signal to ecu missing
Code 16 A/T control signal missing from ecu
Code 21 Main oxygen sensor signal fault
Code 22 Water temperature sensor circuit fault
Code 23 and 24 Intake air temperature signal fault
Code 25 Air/fuel ratio LEAN
Code 26 Air/fuel ratio RICH
Code 27 Sub-oxygen sensor signal or heater circuit fault
Code 28 No. 2 oxygen sensor/heater signal fault
Code 31 and 32 Air flow meter circuit or Vacuum sensor signal fault Code 34 and 36 Turbo-charging pressure signal fault
Code 35 Altitude compensation sensor signal fault
Code 41 Throttle position circuit fault
Code 43 No starter signal to the ecu
Code 51 AC signal on; DL contact off (in transmission shifter with diagnostic connector jumped)
Code 52, 53 and 55 Knock sensor fault Code 71 EGR system malfunction
Code 72 Fuel cut solenoid signal fault
Code 78 Fuel pump control signal fault
Code 81, 83, 84 and 85 TCM communication fault
I am looking for a insruction manual for a Meade autostar DS-2130 AT computer guide telescope
All of Meade's manuals are on this web site-- look toward the bottom of the page--
http://www.meade.com/manuals/index.html
www.telescopeman.org
2helpful
2answers
Toyota 4runner 1994 engine codes 12,52,71 what are these
Code 52 Knock sensor fault
Cant see anything
Can you see anything during the day time? Practice focusing during the day time on a distant object using the eyepiece with the largest number written on it.
The moon should be your first target at night.
The hand control isn't working properly. Haven't used the telescope for 12 months. I have replaced the batteries. When I try to align to a star or other object, the direction buttons only work in one...
First thing to do is to buy a new hand controller cable from Meade, If this does not correct the problem then either the hand controller is defective, or something is broken inside the scope.
Cables are not expensive, call Celestron:
http://www.celestron.com/c3/page.php?PageID=37
13helpful
F1 code on my 2006 suzuki gsxr. it just started an 2 hrs ago drove it home in 20 degree weather now f1 code and no start
When the red light comes on, eg (F1) use these fault codes to find your problem. To extract the codes from the computer system, there is a two pinned connector hanging out of the wiring harness, on the left hand rear of the bike, (say above the pillion foot peg under rear trim. Be sure not to confuse the other connector used by the Suzuki Workshop Mechanics, as this has four or five wires to the connector) After locating the one with only two wires at the back, use a split pin or paper clip to bridge the two wires togeather and turn the ignition to the ON position. You should now be able to read the code on the console. The fault codes are as follows,,
**** GSXR Fuel Injection (FI) Code List:*****
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR C29 - SECONDARY THROTTLE POSITION SENSOR C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
