SOURCE: Config page
You will always use a straight through. The default IP for this is 192.168.1.1 you also need to setup your PC with TCP\IP in order to log in. Go to network connections and double click on the connection for the NIC. high light internet protocol TCP\IP and click properties. then fill this in device IP 192.168.1.1 then PC IP 192.168.1.10 then 255.255.255.0 then hit OK. From there go to your browser and type http://192.168.1.1 there is no password or user name set the first time.
SOURCE: EOC-3220 connects but no internet access
What are you using for Internet connects? do you have the Access point connected to a Router. or is it connected to the Cable or DSL modem. I will need more information to complete this. If you have a router is is set to give an IP address or do you have a static IP? If it is set to give a Dynamic ip change the access point to recieve ip address from router and same with computer. If your connected directly to the Modem with the access point and you only have one IP address it will be used by the access point and not allow the computer to connect.
for more help please provide your internet (DSL, T1, CABLE) if you have router, how it provides IP, and how access point is connected to it.
SOURCE: resetting the senao eoc-3220 long range wireless access point/bridge
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
SOURCE: EOC-3220ext Loosing its wired connection with lan
i have a similar setup with same problems. Senao 3220ext wired to Linksys router which is also a gateway. I have not been able to configure it to work with my Dlink AP2100. only Senao indoor with WDS works with it and disconnects after a few pinging. someone said its compatibility but i feel i have not done something right, DOES ANYONE KNOW HOW This configuration can be done?
SOURCE: how do i reset my engenius senao eoc 3220 outdoor
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
