How do I widen Data Labels in MS Powerpoint Pie Charts?
My Data Labels in my Pie Chart are Category, Value. Even though there is plenty of room in the Pie Slice, the text is wrapping, which I do not want. I click on the Data Label, and though I can move it around, I can't re-size it. I right-click on it, and whether I choose Format Data Label or Format Data Series, there is no option for widening the label, re-sizing it, or de-activating wrap-text. Is there a way I can stretch this Data Label out, so it extends across the whole slice?
Same problem, and it sucks that we can't widen individual labels. Really, really should be fixed. Arrggh!Same problem, and it sucks that we can't widen individual labels. Really, really should be fixed. Arrggh!
You can't post conmments that contain an email address.
Re: How do I widen Data Labels in MS Powerpoint Pie...
Hi There,
What I normally do when the text wraps in a chart, is to click on the chart, then use the Formatting Toolbar, and change the Font Size to 8pt or type '6' in the font size box and enter. this should make your text smaller and it won't be wrapped.
Or select the text in the data label, CTRL+X, and then CTRL+V and you will paste the text as a text box and you can resize the box or made any changes you want
You wouldn't be able to resize the Data Labels. The only thing you can do is either resize the Chart Area so that things will space out accordingly or right-click and format the Data Labels and make the font smaller.
Use PowerPoint Repair Toolbox is efficient PPTX corrupted repair solution for damaged presentations in corresponding format so you may open these documents anytime and regardless the reason of file damage.
For more: https://www.pptxrepairtoolbox.com/
1. Go to the directory where the file is located.
2. Right click on the file
3. Select properties
4. The Type of File, should be PowerPoint Presentation
5. Opens File field should be PowerPoint.
If it doesn't have this, then select the change button & select PowerPoint from the list of applications.
6. Select Ok & then Apply and OK again
7. In case this guide wasn't effective for you, then make use of professional online recovery service for corrupted .ppt and .pptx files https://onlinefilerepair.com/en/powerpoint-repair-online.html PowerPoint repair online
Generally, once a file is corrupt, it's gone. So what I'd do, is just recreate the changes using one of your slightly older versions of the file. This time taking care to make sure you know exactly which one you're editing. Maybe saving a copy to a USB flash drive in addition to uploading a copy somewhere.
Use PowerPoint Repair Toolbox. The PowerPoint repair tool reads and analyzes the damaged files and exports data the restored data to Microsoft PowerPoint. For more: PowerPoint Repair Toolbox
When you are creating charts in Excel a data series refers to the sets of values that are going to be on the chart, be it a line chart, a bar chart, a pie chart etc. Different types of charts can work with different kinds of series. If you select the data you want to chart, and use the Chart Wizard, it will detect what data you have chosen and define it into series for the purposes of being on the chart. You can do things like give names to the series or set colours for them or put titles and legends on the charts for them, and lots of other things. When you are working with a chart, a Chart menu will appear on the menu bar and there are options in it to do things with the different series that are in it.
Chances are you have chosen 'stroke' color as 'blank/empty' in the first pie chart, and 'stroke' color as 'black' in subsequent charts, by mistake. So as a result the charts are having a black outline. You simply have to select 'stroke' or 'outline' color as blank as you did in the first chart. Colors can be chosen in the 'swatches' palette, either for 'fill' or 'stroke' or both. Hope this solves the problem.
Check the source data that it is using to create your chart (right-click choose SOURCE DATA). The result you're getting sounds as if it may not include all the data you want to chart. Generally should include at least two rows AND at least two columns.
