So does your phone give you the object to edit the number. Go to the name that you want to edit and select edit on the top of the name and correct the number. Hope this help!
As you said me you want to delete some contact from you are phone memory means you can do this if you follow this things.Go to menu select contacts then scroll over to delete option and select that option after selecting that you will get two option telling delete all, one by one.If you select all contact will be deleted if you select one by one means you can delete one by one.If you want to edit the number means you can select menu and then contacts there you will get search select it and type the name after getting the contact select option then scroll over to edit number there you can edit.Thanks for you are question happy to help.
Go to Phone book on your phone.
It will display the Names List/Phone numbers you have saved.
Click on the number you want to edit/delete.
Once the name/number is displayed, click on options and then Edit/Delete the Name/Number.
if yor are using s40 series then it would have problem else in s60 u can edit it directly.
in s40 go to my personal configuration in settings.....there you will get option for editing ip,,,,, please specify your nokia model no
To edit your home phone number, press "Where To?" "Favorites" "Home" and then "Edit". You should be able to edit your home location and/or home phone number from there. The unit is also capable of loading the phonebook from your phone, so you might edit the home phone number in your phone, too.
goto phone book hit menu find the number and or persons name you want to edit edit the number hit ok to get to the number or you can do the easier way
delete there name and number and put it back in with the right digits
