Sewing Machines Logo
A
Anonymous Posted on Feb 20, 2018
I own the software program 5D Embroidery System. I recently purchased the 5D Stitch Editor Plus as an add-on package. When I tried to load this, and authenticate it onto my dongle, I get an error saying that I don't have the necessary prerequisite software to permit loading. Any ideas???
5 Related Answers
Ajkill
Anand Kumar
  • 2035 Answers
  • Posted on Jun 27, 2008
SOURCE: Loaded 3D Embroidery software on
Try to install the software from the download as its latest version its will prompt you to remove the old version on your computer and follow onscreen instruction you be able to install the software...........
realyrosey2
  • 8 Answers
  • Posted on Aug 20, 2009
SOURCE: Can't load software w/o the lost Software Licensing code
I too have the 3D Studio, which I purchased from an estate sale. Fortunately, I had the serial number, however I don't have the rest of the registration info to change registration for the program updates. It will not let me install any updates. However, it works just fine without them.
I've heard others with the same problem, and there is no way to bypass their protection codes. Their program also comes with a "dongle", which is a product licensing key, that plugs into your USB port. The program will not run without it. Another item that they will not replace if lost.
I had thought about purchasing another program, but really only needed the new generic reader-writer to plug in to my computer. (It must be an embroidery reader/writer.)
Husqvarna will, however, be happy to sell you another program at great expense.
Alternatively, I would suggest purchasing a more inexpensive program --Embird for expample, and the Ultimate Box (reader/writer) and Card , which will be much cheaper than what the Husky people will sell you. Also, there is no "key" to plug in to operate their program.
Hopefully, the seller can find the registration for it somewhere, because without it, it's pretty useless as far as I know. Husqvarna is very good at protecting their products.
Here is a site with lots of info on both the above items. I bought my reader/writer Ultimate Box Plus and card cheaper from All Brands, though.
Hope all this helps.
deborahcha
  • 371 Answers
  • Posted on Feb 13, 2010
SOURCE: Loaded autodigitizing onto our new computer with
There is an update for dongles and windows 7.
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Good luck.
deborahcha
  • 371 Answers
SOURCE: No Dongle Attached Error Msg
You might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Jul 23, 2011
SOURCE: I have a Designer 1
Those floppy drives that require a dongle are really no good. The USB floppy drives are the way to go. Just plug and play. Here is a link to the USB floppy drives if interested. They start at around $8.00. If you want to stick with the floppy with the dongle, you might want to try running windows update. I didn't see where you posted the maker of the floppy drive or the dongle so getting the drivers or software is pretty much impossible.
1helpful
Which software extensions can be used with a Husqvarna Ruby embroidery sewing machine?
The Husqvarna Designer Ruby can read a number of embroidery file formats: .SHV, .DHV, .HUS, .VIP, .VP3, .PEC, .PCS, .SEW, .JEF, .EXP, .10*, and .DST. One other embroidery file format is accepted. See the manual. It can read the .SH7 stitch format files and .VF3 embroidery font files. It can also read .HTM/ .HTML and .TXT files. With the complimentary 5D software (or a similar package), you can convert most other embroidery files to one that is compatible with the Designer Ruby.
The documentation for many Husqvarna Viking sewing machines is available here: http://www.husqvarnaviking.com/Support . The manual and other useful information for the Designer Ruby is here: http://www.husqvarnaviking.com/support/DESIGNER-RUBY . The current link to the manual is http://www.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_Ruby_manual_ENG_A.pdf?ext=.pdf . The file extensions are listed on page 9:2 (page 100 of the PDF).
I hope this helps.
(I will admit to mostly using the .HUS files with the Designer Ruby.)
2answers
Can I download embroidery editor from janome site instead of downloading from cd
You can download the Artistic Designer program from Janome, https://www.janome.com/products/software/ . However, it will not work unless you have purchased a license key from a dealer. For other Janome software, only updates for supported software are available: https://www.janome.com/support/general-support/software-support/ . You'll either need the program to have been installed on your computer or to put the CD in an optical disc drive. If your current computer doesn't have an optical disc drive, you can get a USB optical drive from Amazon or any other shop that has electronic/computer parts. USB DVD read/write drives are under $50 even at most shops that don't discount accessories. You may need the USB type C (M) to USB type A (female) adapter with some of the newest models (laptops and tablets).
I hope this helps. Please add a comment with the name and version of your software for further assistance. If your software is no longer supported by Janome, there are some third-party embroidery editing software packages. One is https://www.embird.net/ .
I have 5D software and dongle. can't get software to load.
Are you saying your 5D brand Embroidery Patterns won't load to the dongle using Windows 8?
https://www.google.com/#q=5D+Embroidery+won%27t+load+to+dongle+Windows+8%3F&tbs=qdr:y
Here is their Site showing support contact:
Software Help Updates 6D Embroidery System
1helpful
2answers
Husqvarna Viking sewing machine embroidery software: I can't find the TrueType Wizard which would allow me to convert regular computer fonts into stitch files. Professional Plus software.
There are two ways to convert the True Type fonts on your computer to embroidery. One is within the program, one is independent. To locate the independent one, locate your Programs folder on your computer then the folder containing your embroidery software. There should be a QuickFont.exe file there you can use. The best way however is to use the one within the program. On your Letter tab, up where the types of fonts are listed with radio buttons, there should be a QF icon. Click on that and you are away. The two programs are not exactly the same and whilst I have forgotten the differences, the one inside the customising program is the better one to use.
1helpful
I have a Husqvarna 1250/Viking 1+ that my aunt recently gave me when she upgraded machines. I have installed the Customizing 95 (version 1.31) software on my laptop and it works fine. However, I can not...
1. Did the software come with a dongle? This is a "key" that looks like a memory stick, that is actually a copyright protection device. You cannot access the program without it. To get the program to recognize it. plug it into a free USB Port, then power up your computer. It will read the dongle as a new device and install it on your computer. Always make sure the dongle is plugged into the same USB port as when its installation.
2. Check the operating system compatibility of your embroidery software and your computer.
What is your computer's OS? If you have Vista, it will not read Win95-XP. In that case, you may need to find a used computer to dedicate to your embroidery and install Win 98. I have XP 2000 and it reads all the Win programs back through 95.
My Husqvarna Rose/3D Embroidery Studio, will not operate with the Vista program. It will run on XP, because XP is backward compatible to previous Windows programs.
If this is the problem, you can still purchase older Windows programs very affordably. Before installing it on your hard drive, I would get expert instructions from a professional, who would back up your hard drive. I've also heard of people partitioning their hard drives, so that they could use more than one operating system.
(This is MUCH CHEAPER than purchasing a new machine and all the software, etc to go with.)
Just a note: The small notebooks they've come out with, do not have the proper drive to run your embroidery program.
3. If you have the reader'writer that came with the machine and no serial port on your computer or printer, you can take the box to your local Radio Shack or computer repair, where you can get an adapter with a serial plug on one end and a USB plug on the other, or get the "Ultimate Box Plus". The adapter is cheaper.
One, or all, of these little tidbits may fit your problem.
Hope this helps.
4helpful
2answers
Baby Lock Embroidery Sewing Machine "ELLURE" Model ESL- Problem: Defective Embroidery Memory Card (part#35205-4) used with the "PTS BOX" and the Palette Ver 1.0 Software Program to transfer embroidery...
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
I am trying to use the "Place and Stitch embroidery" software
You have to have the computer program to merge patterns.
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
