Posted on Apr 29, 2009
1000 suply error - Office Equipment & Supplies
Anonymous
Level 1:
  • Contributor 122 Answers
  • Posted on Apr 29, 2009
Anonymous
Contributor
Level 1:
Answers
122
Questions
0
Helped
49484
Points
46
To bar all incoming calls
To start, enter *35* password #
To stop, enter #35* password #
To bar all outgoing calls
To start, enter *33* password #
To stop, enter #33* password #
To bar all outgoing ISD calls
To start, enter *331 password #
To stop, enter #331 password #
Sala
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 05, 2018
Sala
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
278
Points
I forgot my htc call barring password
Power suply
Shop for Televisions Power supply on Google
SoundPoint IP 24V Universal...
$9.99
Google Trusted StoreMetroline... EVGA 120?G1?1000...
$139.99
Google Trusted StoreNewegg.c...
(28) Thermaltake ? Tr2?600nl2nc...
$44.99
Best Buy
In store Rosewill Stallion Series...
$39.99
(406) 1000W Power Supply
$155.99
(58) Search Results
    Power Supply Boards - TV Parts - ShopJimmy
2helpful
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
I need a power cord for this Maxtor 3200 - please advise [email protected]
wath kind of power connetions ?
round 6 mm outsite negative insite positive (12 volts)
if yes you buy power suply wit at minimum output over 1000 mA how more are better
When i power on a led is blinking next to the mb power suply and apears two errors 82 and 98 i have tried diferrent power suply, ram, vga card
remove the bios battery for 20- 25 mins.small flat round battery on the motherboard then put it back in. start up computer
Lost my power suply, what voltige and polarity?
You can consult the manual.
http://h10032.www1.hp.com/ctg/Manual/bpu80012.pdf
E 065 error code
change the composite power suply board
2answers
SONY - PFM-500A2WE 16:9 42-inch Plasma fault 22-12
The error code tyo which you refer was truncated off of your posting. Could you please enter that code again? That code will assist us in determining the problem circuit.
Thanks,
Dan
Hp color laserjet 2600n giving "10.0000 suply error"
10.00 error is for the black cartridge. Check the cartridge locker for the black toner cartridge on the right side, is it different from the other? does it moves correctly? check properly. If the locker seems correct, try clean the contacts on toner and opposite HV pins in printer
2answers
My Worcester Greenstar HE boiler is showing an error sign (EA) and I dont have the manual for it. The system has not been turned on for over a year.
i have the same boiler and this code refers to gays suply error, i would suggest a engineer to yake a look at it but first check if ur gas suply is ON ...!
2answers
Akai 2662
I have to assume that your post is some question concerning the SMPS on the Akai TV and then further assume that you're dealing with a dead condition??? That given, you probably need to replace several caps on the SMPS that can be ordered as a kit. The kit supplies 19 caps in-all (4) 3300/35v, (8) 2200/25v, (6) 1000/10v and (1) 1000/16v the last seven 1000uf caps can all be 16v if you order the smaller style.
That is assuming you are experiencing a dead condition on your set. It is best if you can give a tech a little more to go on than "power suply" if you're actually wanting any real help.
Bill
k24674
ADMIN Andrew
ADMIN Andrew
