I nead instructions how to disasemble the Genius vibrating headset i am having problems with cable in L speaker headset when i tilt my head to left sound is interupted can i get instructions how to disasemble it??
Determining the Cause of the Problem
Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit.
Testing for a Speaker Problem
With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker
Testing for an Amplifier Problem
Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system.
Testing for an RCA Cable Problem
For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover.
esting for a Crossover or Equalizer Problem
At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem
Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
With game (any) loaded, you can usually see whether your version supports vibration although my games only list joystick/controllers.
Maybe CSGO has Vibr Headset option as well?
In any case, go to settings, then either controllers or sound settings, look for anything to do with vibration.
Then activate the option.
As I don't have the actual game, my help is just generic.
Hope it helps a bit.
Then you have a broken wire and you need to take it to someone that knows wiring. An electronic shop should be able to help with that. Inside the wire are lots of thin copper wires and if one or two of them are broken then you will have a problem.
Even I have encountered the same problem with Logitech headset.Also my microphone is not working at all.
I thing I noticed that when I tilt the cable connected at the end of microphone towards the other direction both the speakers work as I hold the cable in that position.But when I release the cable only one of them works.
Based on your post/description, it would seem that the cable of your head phone developed an open circuit somewhere. I would assume it is pretty near the headset itself. On most occasion, it is at the very entry point where the cable goes into the headset.
Normal repair would involve opening the side casing where the cable enters the headset, cutting the cable about 3 inches from entry point, strip exposing the three or 4 wires and reconnecting inside the stripped ends. Effectively what you have done is trim the cable a bit shorter eliminating hopefully the intermittent section.
Hope this be of help/idea, Post back how things turned out or should you need additional information.
