Junk axial wobble plate pump. Usually axial pumps are not worth the time to try to fix them. This one has a 5 year warranty , so they think they have a pretty good one. ( I would never buy one) If you want to try to fix it, I would check the check valves first. Take them out and see if some are broken or not sealing properly. There is a valve kit available.
The other likely problem is your unloader valve. If the seal is shot or the valve stuck open the pump will not build pressure.
parts diagram http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/axd-PUMP%20BREAKDOWN.pdf
SOURCE: I have a northstar pressure washer with a comet
Normally, it is one of three things.
1.) The high pressure seals are bad
2.) There is debris in the check valves
3.) the unloader is stuck in by-pass.
SOURCE: what type of oil goes in a comet axd 3020 pressure
You should use what the pump manufacturer recommends. Typically a 30wt non-detergent (non foaming) oil. Do not over fill. If there is a sight glass half way is normal. Or if it has a dip stick follow the mark there.
Here is a great link for pressure washer parts and info
This link goes right to oil page:
http://pressure-washer-parts.com/shopdisplayproducts.asp?Search=Yes
