SOURCE: Registering phones
I have after many hours found the solution. (Well one that worked for me). I have a Uniden Elite 8855 + 8805 additional handsets. What you have to do is:
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
SOURCE: No dial tone
my base unit did the same.... power from the wall was out ... check GFI switch.
SOURCE: Phone says OUT OF RANGE while on the base and won't work.
The handset has lost the link with the base. This link codes the handset to the base with a unique security code so others with the same phone cannot use your phone line.
If you changed the battery, try disconnecting the base telephone line and ac adapter for a while (1/2 hour or so if possible).
Remove the battery from the handset as well.
After 1/2 hour, install the battery in the handset, connect the telephone line and ac adapter to the base. Place the handset in the charging base and the link should be established. If not, the phone is defective.
[email protected]
SOURCE: GE 5.8GHz portable phone. Have lost function on
click or copy this link to your browser to download new manual for your phone http://phone.manualsonline.com/manuals/mfg/ge_appliances/ge_appliances_cordless_telephone_product_list.html
