Behringer B3031A 2-Way Active Studio Monitors Logo
S
Steve Demuth Posted on Oct 31, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get a schematic for the output section of the mixer on a behringer 1280s?
Fred Yearian
Level 3:
  • Behringer Master 5,603 Answers
  • Posted on Aug 27, 2015
Fred Yearian
Behringer Master
Level 3:
Answers
5603
Questions
Helped
2250256
Points
16163
The schematics are on the Elektrotanya.com site.
Megasong
Level 2:
Scholar:
New Friend:
  • Expert 125 Answers
  • Posted on Feb 11, 2014
Megasong
Expert
Level 2:
Scholar:
New Friend:
Answers
125
Questions
0
Helped
43125
Points
141
No hope. I have replied to this sort of question elsewhere but Behringer are very protective of their stuff and won't even let us have diagrams. Only Behringer service. If anyone has any Behringer service manuals / schematics we would love them
4 Related Answers
Fred Yearian
  • 5603 Answers
  • Posted on Apr 28, 2010
SOURCE: LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Fred Yearian
  • 5603 Answers
  • Posted on Nov 27, 2010
SOURCE: My Behringer Europower Pmp5000 Powered Mixer blew
Probably the channel A went. If you are fortunate, the power supply is still OK. There are protection circuits for the speakers, however you MUST use speakers that are rated at over 400 Watts. If you use smaller ones, they can get blown. There is a weakness primarily on insulation for channel A and an arc between layers of a circuit board can wipe out several transistors and a zener diode and sometimes a metering resistor. Once this happens, have unit serviced before using it again as further damage can result.
ALSO PLEASE read my tip I posted on FIXYA regarding a grounding hazard when using Speakon to 1/4 inch speaker cables... essentially the barrel of the 1/4 inch jack of the A channel is the hot lead, NOT the tip for that channel.
Fred Yearian
  • 5603 Answers
  • Posted on Nov 30, 2010
SOURCE: I am an elec tech of 30 years. I have 2 Behringer
Try this site... you may have to log in...
http://elektrotanya.com/behringer_k1800fx_sch.pdf/download.html
If it doesn't work, email me at my email address with K1800FX in the subject line and I will send you the PDF.
Fred Yearian
  • 5603 Answers
  • Posted on Feb 06, 2011
SOURCE: Does anybody have a schematic for the Behringer
Look at this one:
This is for the 1800 however...
Often they will just double up with two amps, one inverted, and use in bridged mode.at the higher power in what we call an "H" arrangement.
Since the drains are tied together, the heatsinks MIGHT be hot output level.
2answers
Behringer pmp1280s circuits diagram
sir,send me behringer pmp1280s circuits diagram .
send me my facebook [email protected] pls....
Aug 05, 2013 • Music
I have a behringer pmp 1280s. I was running two speaker and two monitors through it. One of the monitors was kicked and the patch cable to it was bent. I smelled smoke and the sound coming through turned...
That's a bad sign. A dead short in the output results in a short of the audio output transistors. I believe that to be the problem and a fairly simple fix to someone good at soldering BUT, you can't get parts for behringer equipment. Most components are specially made for behringer. I've been working on an amp for 6 months and I can fix it BUT, I can't find the parts anywhere, or can even find any reference to them online. Without a reference to the specs, I can't even get a generic replacement. Check your music stores in you area, a behringer dealer may can help you.
Mar 03, 2013 • Music
I have Behringer xenyx 1622fx , It will turn on the power but a few minute the power will turn -off , Please help me to solve the problem of this unit in power supply section or other section.
Here is your schematic:
http://elektrotanya.com/behringer_xenyx_1622fx.pdf/download.html
Scroll down and find link "Get manual" and click to download.. IGNORE other download links they are for third party viewers. Power supply is on page 11. This is a switching power supply running from line voltage. For personal safety USE AN ISOLATION transformer when working on it. First thing is to measure all the voltage outputs before and during shutdown. Switching power supplies often require use of an oscilloscope to repair. The three terminal regulators that follow the main switching supply each have thermal shutdown so if one of them is being overloaded it will shutdown and that voltage will drop way down. Use great caution when working on the supply!!!
How much output power supply behringer xenyx 1832fx?
The supply will be similar to that in the 1222. Download a schematic here. Look at the SPUS2 portion of the compressed file.
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
There are several voltages present.
2helpful
Where can i get a schematic for the xenyx 1002 mixer
Try this:
http://elektrotanya.com/behringer_xenyx_1202.pdf/download.html
This is for slightly different model, however Behringer uses same circuits in most of this series... AND they don't give out schematics.
1helpful
2answers
I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
1helpful
2answers
I need a wiring diagram for the main circuit board in a behringer djx700 mixer
Behringer only gives schematics to their authorized service people.
I find I can usually trace stuff out as needed as the mixers are a very symetrical repeating circuitry.
Most components are readily available from other sources.
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
