Sanyo DP42848 LCD TV Logo
K
Klaus Tretter Posted on Oct 31, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SANYO DP 42848 NTSC to PAL - Sanyo DP42848 LCD TV
Level 3:
Top Expert:
  • Sanyo Master 76,851 Answers
  • Posted on Oct 31, 2013
Sanyo Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006609
Points
237762
The TV you specified here can only be used with NTSC system transmission or video data. If you wish to see PAL system signals by this tV, you've to buy PAL to NTSC converter, and should connect it according to connection diagram given along with the converter.
3 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Mar 31, 2011
SOURCE: DP 42848 Sanyo
It can be the 24vdc power supply problem which supplies the power for the backlights inverter board, or the backlights inverter board is bad, or T-CON board is bad, you need to do this when the screen goes black:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Anonymous
  • 131 Answers
  • Posted on Jun 27, 2011
SOURCE: I have a Sanyo Tv
Hello; The LCD panel is the likely cause of this problem. It can cost as much or more than a new TV. Bad inverter board(s). There are usually one to four of these PC boards. They light up the tiny florescent tubes behind the LCD panel. They are just like a ballast in the old florescent lights. The problem is that the manufacturer that made the LCD panel , also made the inverter boards that are in or on it and are NOT available separately. These are the high voltage power supplies that light up the " backlights behind the screen. The microcomputer in the TV watches these come on. If there is something wrong with one, it will shutdown the set.
gopakumarg43
  • 76851 Answers
  • Posted on Jun 07, 2012
SOURCE: sanyo model 42848 tv parts diagram
Download its service manual. Try this link to download it.
1helpful
I have a Sanyo 39" LED TV model #FVE3923 being used in the USA. We are moving to Germany and need to know if it has a built in NTSC-PAL Video Switch or will a switching converter be needed
If the set have been aimed to work in US only, there will be no set-up switch or any such. If the set is a multi system one (you can get this detail by its user manual_specifications), it can be used with PAL too.
Have a sanyo tv that i change power board and still clicks
Flickering? I could see a problem with little older TV`s if you got PAL TV in NTSC zone and vice versa...
How to convert sanyo dvr DSR300N(NTSC) to DSR300P(PAL)?
You have to buy one NTSC to PAL signal converter for this, and connect it in beween your tV and DVR.
1helpful
2answers
How do i change my channel tuner from NTSC to PAL?
you need to get a converter that takes pal and converts it to ntsc.
1helpful
I bought an HDTV LCD Sanyo from USA got it with me to Lebanon, when I turn the TV on the picture is so clear but it will not work on the satelite or caple, the picture not clear and has no voice. I need to...
There are currently 3 main television standards used throughout the world:
NTSC - National Television Standards Committee. The oldest existing standard, developed in the USA. First used in 1954. Consists of 525 horizontal lines of display and 60 vertical lines. Sometimes irreverently referred to as "Never Twice the Same Color." Only one type exists, known as NTSC M.
Here is a list of TV STANDAREDS I had for a while and can finally share it with someone. GOOD LUCK!!!! TECHMAN
SECAM - Système électronique pour Couleur avec Mémoire. Developed in France. First used in 1967. A 625-line vertical, 50-line horizontal display. Sometimes referred to by wags as "Something Essentially Contrary to the American Method" or SEcond Colour Always Magenta!" Different types use different video bandwidth and audio carrier specs. Types B and D usually used for VHF; types G, H, and K for UHF; types I, N, M, K1 and L for both VHF/UHF. Different types are generally not compatible.
PAL - Phase Alternating Line. Developed by German engineer Walter Bruch and the German electronic corporation Telefunken. Walter Bruch
patented his invention 1963 and the first commercial application of the PAL system was in August 1967. Also a 625/50-line display and variant of NTSC. Proponents call it "Perfection At Last." Due to the cost of the enormous circuit complexity, critics often refer to it as "Pay A Lot". Different types use different video bandwidth and audio carrier specs. Common types are B, G and H; less common types include D, I, K, N and M. The different types are generally not compatible.
Television Standards by Country
COUNTRY SIGNAL TYPE
AFGHANISTAN PAL B, SECAM B
ALBANIA
PAL B/G
ALGERIA
PAL B/G
ANGOLA PAL I
ANTARCTICA NTSC M
ANTIGUA & BARBUDA
NTSC M
ARGENTINA
PAL N
ARMENIA SECAM D/K
ARUBA
NTSC M
AUSTRALIA
PAL B/G
AUSTRIA
PAL B/G
AZERBAIJAN SECAM D/K
AZORES PAL B
BAHAMAS
NTSC M
BAHRAIN
PAL B/G
BANGLADESH
PAL B
BARBADOS
NTSC M
BELARUS SECAM D/K
BELGIUM
PAL B/H
BELGIUM (ARMED FORCES NETWORK) NTSC M
BELIZE
NTSC M
BENIN SECAM K
BERMUDA
NTSC M
BOLIVIA
NTSC M
BOSNIA/HERZEGOVINA
PAL B/H
BOTSWANA SECAM K, PAL I
BRAZIL
PAL M
BRITISH INDIAN OCEAN TERRITORY
(AF DIEGO GARCIA TV - AFRTS) NTSC M
BRUNEI DARUSSALAM
PAL B
BULGARIA
PAL
BURKINA FASO SECAM K
BURUNDI SECAM K
CAMBODIA
PAL B/G, NTSC M
CAMEROON PAL B/G
CANADA
NTSC M
CANARY ISLANDS
PAL B/G
CENTRAL AFRICAN REPUBLIC SECAM K
CHAD SECAM D
CHILE
NTSC M
CHINA (PEOPLE'S REPUBLIC)
PAL D
COLOMBIA
NTSC M
CONGO (PEOPLE'S REPUBLIC) SECAM K
CONGO, DEM. REP. (ZAIRE)
SECAM K
COOK ISLANDS PAL B
COSTA RICA
NTSC M
COTE D'IVOIRE (IVORY COAST) SECAM K/D
CROATIA
PAL B/H
CUBA
NTSC M
CYPRUS
PAL B/G
CZECH REPUBLIC
PAL B/G (cable), PAL D/K (broadcast)
DENMARK
PAL B/G
DIEGO GARCIA NTSC M
DJIBOUTI SECAM K
DOMINICA
NTSC M
DOMINICAN REPUBLIC
NTSC M
EAST TIMOR
PAL B
EASTER ISLAND PAL B
ECUADOR
NTSC M
EGYPT
PAL B/G, SECAM B/G
EL SALVADOR
NTSC M
EQUITORIAL GUINEA SECAM B
ESTONIA PAL B/G
ETHIOPIA PAL B
FALKLAND ISLANDS (LAS MALVINAS) PAL I
FIJI NTSC M
FINLAND
PAL B/G
FRANCE
SECAM L
FRANCE (FRENCH FORCES TV) SECAM G
GABON SECAM K
GALAPAGOS ISLANDS NTSC M
GAMBIA PAL B
GEORGIA SECAM D/K
GERMANY
PAL B/G
GERMANY (ARMED FORCES TV GERMANY) NTSC M
GHANA
PAL B/G
GIBRALTAR
PAL B/G
GREECE
PAL B/G
GREENLAND
PAL B
GRENADA
NTSC M
GUAM
NTSC M
GUADELOUPE SECAM K
GUATEMALA
NTSC M
GUIANA (FRENCH) SECAM K
GUINEA PAL K
GUYANA NTSC M
HAITI
SECAM
HONDURAS
NTSC M
HONG KONG
PAL I
HUNGARY
PAL K/K
ICELAND
PAL B/G
INDIA
PAL B
INDONESIA
PAL B
IRAN
PAL B/G
IRAQ
PAL
IRELAND, REPUBLIC OF
PAL I
ISLE OF MAN
PAL
ISRAEL
PAL B/G
ITALY
PAL B/G
JAMAICA
NTSC M
JAPAN
NTSC M
JOHNSTONE ISLAND NTSC M
JORDAN
PAL B/G
KAZAKHSTAN SECAM D/K
KENYA
PAL B/G
KOREA (NORTH)
SECAM D, PAL D/K
KOREA (SOUTH)
NTSC M
KUWAIT
PAL B/G
KYRGYZ REPUBLIC SECAM D/K
LAOS PAL B
LATVIA PAL B/G, SECAM D/K
LEBANON
PAL B/G
LESOTHO PAL K
LIBERIA
PAL B/H
LIBYA
PAL B/G
LIECHTENSTEIN
PAL B/G
LITHUANIA PAL B/G, SECAM D/K
LUXEMBOURG
PAL B/G, SECAM L
MACAU PAL I
MACEDONIA PAL B/H
MADAGASCAR SECAM K
MADEIRA PAL B
MALAYSIA
PAL B
MALDIVES PAL B
MALI SECAM K
MALTA
PAL B
MARSHALL ISLANDS NTSC M
MARTINIQUE
SECAM K
MAURITANIA SECAM B
MAURITIUS
SECAM B
MAYOTTE SECAM K
MEXICO
NTSC M
MICRONESIA
NTSC M
MIDWAY ISLAND NTSC M
MOLDOVA (MOLDAVIA) SECAM D/K
MONACO
SECAM L, PAL G
MONGOLIA SECAM D
MONTSERRAT NTSC M
MOROCCO
SECAM B
MOZAMBIQUE PAL B
MYANMAR (BURMA)
NTSC M
NAMIBIA PAL I
NEPAL B
NETHERLANDS
PAL B/G
NETHERLANDS (ARMED FORCES NETWORK) NTSC M
NETHERLANDS ANTILLES NTSC M
NEW CALEDONIA SECAM K
NEW ZEALAND
PAL B/G
NICARAGUA
NTSC M
NIGER SECAM K
NIGERIA
PAL B/G
NORFOLK ISLAND PAL B
NORTH MARIANA ISLANDS NTSC M
NORWAY
PAL B/G
OMAN
PAL B/G
PAKISTAN
PAL B
PALAU NTSC M
PANAMA
NTSC M
PAPUA NEW GUINEA PAL B/G
PARAGUAY PAL N
PERU
NTSC M
PHILIPPINES
NTSC M
POLAND
PAL D/K
POLYNESIA (FRENCH) SECAM K
PORTUGAL
PAL B/G
PUERTO RICO
NTSC M
QATAR
PAL B
REUNION SECAM K
ROMANIA
PAL D/G
RUSSIA
SECAM D/K
ST. KITTS & NEVIS
NTSC M
ST. LUCIA
NTSC M
ST. PIERRE ET MIQUELON SECAM K
ST. VINCENT
NTSC M
SAO TOMé E PRINCIPE PAL B/G
SAMOA, AMERICAN
NTSC
SAUDI ARABIA
SECAM B/G, PAL B
SAMOA NTSC M
SENEGAL
SECAM K
SEYCHELLES PAL B/G
SIERRA LEONE
PAL B/G
SINGAPORE
PAL B/G
SLOVAKIA PAL B/G
SLOVENIA PAL B/H
SOMALIA PAL B/G
SOUTH AFRICA
PAL I
SPAIN
PAL B/G
SRI LANKA PAL
SUDAN
PAL B
SURINAME
NTSC M
SWAZILAND PAL B/G
SWEDEN
PAL B/G
SWITZERLAND
PAL B/G
SYRIA SECAM B, PAL G
TAHITI
SECAM
TAIWAN
NTSC
TAJIKISTAN SECAM D/K
TANZANIA
PAL B
THAILAND
PAL B/M
TOGO
SECAM K
TRINIDAD & TOBAGO
NTSC M
TUNISIA
SECAM B/G
TURKEY
PAL B
TURKMENISTAN SECAM D/K
TURKS & CAICOS ISLANDS NTSC M
UGANDA
PAL B/G
UKRAINE
SECAM D/K
URUGUAY PAL N
UNITED ARAB EMIRATES
PAL B/G
UNITED STATES
NTSC M
UNITED KINGDOM
PAL I
UZBEKISTAN SECAM D/K
VENEZUELA
NTSC M
VIETNAM
NTSC M,SECAM D
VIRGIN ISLANDS (US & BRITISH)
NTSC M
WALLIS & FUTUNA SECAM K
YEMEN
PAL B/NTSC M
YUGOSLAVIA PAL B/G
ZAMBIA
PAL B/G
ZIMBABWE
PAL B/G
2answers
Rf signal pal to ntsc
there should be an option in your picture settings menu
1helpful
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Video output format
Yes you can here is a link to a device that can help: http://www.goldenshop.com.hk/AI-trad/Misc_htm/m_pal2n.htm also try http://www.bizrate.com/videoaccessories/products__keyword--pal+ntsc+converter.html I hope this helps Shuttle83
TV SANYO MODEL DS 25390
It would be a waste to take this TV to Brazil, as this is not a Multi system TV, and will not recieve PAL M broadcasts.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
