Question about Mustek PVR-H230 MP3 Player
I MISTAKENLY REMOVED PVRDATA FROM MY H230 AND I WANT TO RESTORE THEM NOW SO THAT THE DEVICE WILL WORK PROPERLY AGAIN
  • PETER J BANGURA
    PETER J BANGURA Nov 03, 2013
    I mistakenly removed the pvrdata from my yukai H-230 and i cannot restore it in spite of all my trials. Now when i switch on this H-230 device, it diplays this statement " UI RESOURCE DATA MISSING, CONNECT TO PC".I have followed this instruction but i still cannot access my files. How can restore this pvrdata to my H-230 device?
HALionONE is missing some files. I guess I deleted them mistakenly. When I look at Devices and Plugins information , it shows missing Plugin. How can I resolve this
The best way to restore deleted files associated with the program is to re-install the software. This way you will insure that the program works properly.
Some software when you delete it from the system before re-installing it, will ask if you want to repair it. You can choose that option, if it becomes available.
Aug 01, 2016 | Steinberg Cubase 5 Full Version for PC,...
Installed a new router and now my speakers don't work. How do I fix this?
The router change shouldn't have any affect on your sound or your speakers. You need to start checking things out. Is sound accidentally shut off at the speakers?? Have speakers came unplugged at back of computer?? Has the sound been mistakenly shut off at the keyboard?
Dec 03, 2013 | Amazon Kindle Fire HD
Accidentally deleted icons & set up information.
open recyclebin and look for the icon and click restore. . .
thanks and have a nice day ahead.. . .
May 06, 2011 | Mustek PVR-H230 MP3 Player
Good Morning! Please help me how to restore the function of my laptop USB port, when i connect even flash drive, printer, scanner to my usb port it dosn't work properly, its hang then when i remove and...
Have you tried to shut down your computer and re-start it up again ? (to see if your USB port starts to works again ?)
One thing you should (must) do before you remove / detach a USB device (e.g. flash drive, camera, etc.) from the USB port is to make sure you properly "dismount" (eject/disconnect) the device first (e.g. use its Property menu option) before you physically remove the device (i.e. take it out - remove it from the USB port). If this is not done, you'll get the problems you're experiencing.
Jan 02, 2011 | Computers & Internet
My computer doesnt have a sound eventhough I have the speaker yet but it is still not working.. my mistaken was when I try to remove some programs on my computer, I pick to remove it, I thingk it is one of...
try to restore your computer on system tools option...restore your system in the date when you removed the program...
or get the driver in the internet ..motherboard website and exact model then get only a driver for your Operating system...
or buy PCI sound card last option..
May 26, 2010 | Audio Players & Recorders
Sd memory card don't work i have windows 7
Hey can u point me to the 3 unknown drivers in Windows 7 for this device??
Jan 06, 2010 | Fujitsu Siemens CELSIUS H230 Notebook
I mistakenly ejected my ipod from my computer
DID you try to reset it before you restored it:
Before beginning plug your ipod into your pc :
1: Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.
2:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Pressand hold the Menu and Center (Select) buttons simultaneously until theApple2.gif logo appears, about 6 to 8 seconds. You may need to repeat thisstep
Nov 09, 2009 | Apple iPod MA446LL/A MP3 Player
I flashed new bios on my CELSIH230, and now the computer is dead.
The new bios you flashed is either not compatible with your system or has been incompletely flashed, you need to restore the correct bios for the system, for this you would require a floppy drive, the bios is divided into two regions static and volatile, routines in the static region cannot be changed and supports booting from legacy devices like floppy drive. you need to copy the bios files into the floppy and use this floppy to restore the bios, I have tried this on desktops 4-5 years ago, For this you need to power-on the system with holding some specific keys (the keys differ from system to system)
Oct 08, 2009 | Fujitsu Siemens CELSIUS H230 Notebook
Can not get songs to play. They list and everything else works, but no songs can be heard,and the click is not working or heard.
Restore your computer to the date you the device worked well last. To do this go to start/all programs/accessories/system tools/system restore. When the system restore dialogue box comes up, make sure to select a date on which the device worked properly. If the date there are too early, choose "choose a different restore point" and if still necessary choose "dates more than 5 days old." Then click restore. You will not loose personal data. At the end of restore try your device again and it should work properly as it did previously on that date.
Oct 01, 2009 | Yamaha Dtxpress III Electronic Drum Set...
No system boot files
seach for PVRDATA on your software disk and copy it to the device in windows - works fine
Nov 26, 2008 | Goodmans GPDR40 Digital Media Player
Mustek PVR-H230 MP3 Player Logo
63 people viewed this question
Top Mustek Audio Players & Recorders Experts
John Elliott
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
