Motorola Mobility SLVR L7 Cellular Phone Logo
Posted on Oct 01, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keypad strange beahiour
When the phone starts, all the keys work properly. However, if I press either "7", "right soft key" or "hung up key", all the rest of the keys are dissabled from that moment on. Only these 3 keys keep working. To reenable the keypad, I need to pull the battery out. I flashed the phone but this did not help. I do not know the history of the phone, so I don't know why or when this behaviour started to happen. HELP!
Anonymous
Level 2:
  • Expert 89 Answers
  • Posted on Oct 02, 2007
Anonymous
Expert
Level 2:
Answers
89
Questions
0
Helped
30193
Points
114
Seems like you phone is repaired or have been fell very badly that you key pad have been displaced inside look for some one who can repair it for you .
HOW DO I MASTER RESET MY SGH-A847 WITH THE HARD KEYS?
  1. While in standby mode, press the right soft key for Menu
  2. Select Settings
  3. Select Phone
  4. Select Reset Settings
  5. Enter the password, using the keypad
    • If no password has been created, enter 0000
  6. Press the left soft key for Confirm
  7. Enter the password again to confirm, using the keypad
  8. Press the left soft key for OK
  9. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Note: The device will power cycle to complete the restting. All device settings will be reset to factory settings.
How do i factory reset on my SGH-A847?
  2. Select Settings
  3. Select Phone
Buttons won't work. Just returned from a 6 day golf trip where the SkyCaddie SG4 worked perfectly for the first 5 days. I recharged it in a wll outlet overnight, then on the next day the buttons...
Power On/Off and Key Lock/Unlock - Press the Power button located at the top right
of the Sky Caddie to power on/off or to lock/unlock the keypad. Upon pressing
the Power button you are prompted to choose either "Off" (Left Soft Key) to power
off the device or "Lock" (Right Soft Key) to lock the keypad. To unlock the keypad,
select 'Unlock" by pressing the Right Soft Key, then choose "Yes".
2helpful
I want to know if there's a way / software to sync my Samsung SGH-i607 with my Gmail account.
Yes, the SGH-i607 can support an IMAP account, and Gmail can be accessed through IMAP. They don't list the SGH-i607 as a supported client, but it should be possible to configure it to work with Gmail.
First, go to your gmail account and enable IMAP:
Sign in to Gmail. Click the gear icon in the upper-right and select Gmail settings at the top of any Gmail page. Click Forwarding and POP/IMAP. Select Enable IMAP. Click Save Changes.
Next, configure the SGH-i607:
While in standby mode, press the left soft key for Start Select Messaging Select New Account (3) Select Other (POP3/IMAP), using the navigation keys Press the right soft key for Next Enter your name & E-mail address, using the Qwerty keypad Press the right soft key for Next For User Name, enter your full email address (including @gmail.com), using the Qwerty keypad . For Password, enter your Gmail password. For Domain, enter gmail.com. Press the right soft key for Next. For Server Type, choose IMAP. For Account Name, enter your full email address (including @gmail.com). Press the right soft key for Next. For Incoming Server, enter imap.gmail.com and select "Require SSL connection". For Outgoing Server, enter smtp.gmail.com and select "Outgoing server requires authentication". Press the right soft key for Next. Select desired message settings, using the navigation keys. Press the right soft key for Next. Select desired configurations for Storage and Connection. Press the right soft key for Next. After you have determined how often the device will connect, press the right soft key for Next. Setup will now be complete. Pressing the right soft key for Finish will enter the newly-created account in the Messaging application.
3helpful
My spouse changed my security and phonelock codes
Try this out:
  • Press Menu
  • Use the Navigation Key to scroll to Settings and press the Center Select Key
  • Use the Navigation Key to scroll down to Security and press the Center Select Key
  • Use the Navigation Key to scroll down to New Passwords and press the Center Select Key
  • Use the Navigation Key to scroll down to Unlock Code and Press the Center Select Key
  • Press the keypad to Enter Old Unlock Code (Default 1234) and select OK by pressing the right soft key. If you have forgotten the unlock code, press Menu and enter the Security Code (000000)
  • Press the keypad to Enter New Unlock Code and select OK by pressing the right soft key
  • Press the keypad to Re-enter New Unlock Code and select OK by pressing the right soft key
1helpful
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
2helpful
Razr V3 audio will only work on speaker phone
If you quickly enther ##debug (##33284). if the 4 doesn't appear then that means the phone regognized the code. press END then once you see you home screen press CLR and then the LEFT SOFT key which brings you into the debug mode. ONce your in there be very carful not to change any settings for it can easily screw up your phone so be cautious. to go through the pages press the LEFT or RIGHT SOFT keys. more prefferd by pressing the RIGHT one. press it a few times till you come to the page where the first line says "ServOPT: NoChg". The second line or the line right after that says "AudioOpt: Auto". Scroll down to it by pressing the down button on your keypad then once the little pointer on the left of the screen is at "AudioOPT:". you'll notice that right on top of the RIGHT SOFT key says change. Pess that till it goes from "Auto" to "Spkr". once your finished all that press Exit (LEFT SOFT KEY) and you will see it going out of the editing mood. Press CLR and the LEFT SOFT key on the keypad again to Exit the debug mode. Once you out to the main screen again press ##debug again to disactivate the Debug mode. Again if the 4 doesn't appear then that means the code registered and it disactivated. If you won't disactivate it it will enter into the mode again by switching your phone off and on again. which you don't want to happen. however if it does happen press the CLR and LEFT SOFT key then you out again. then disactivate it again by pressing ##debug.
If that doesn't solve your problem then i'm sorry but i can't help you. I am also not responsible if you Screw up your Phone.
This only works on the Razr phones so don't try it on other phones.
4helpful
4answers
Keypad problem
hi my n73 keypad is nt working' all keys nt work
6helpful
5answers
Nokia 1100 keypad lock code
i have a nokia 1100 ,its keypad lock no not working / please advise me to unlock the keypad.....
May 03, 2008 • Nokia 1100
1helpful
How to send picture msg
Here's how send a picture in a message.
1. Press the Center Select Key
2. Press the Navigation Key to scroll to Messaging, and press the Center Select Key
3. Press the Navigation Key and scroll down to Create Message, and press the Center Select Key
4. Press the Navigation Key and scroll down to New MMS Message, and press the Center Select Key
5. Press the keypad to enter desired text
6. Press Options, by pressing the left soft key
7. Highlight Insert, and press the Center Select Key
8. Highlight Picture, and press the Center Select Key
9. Press the Navigation Key and scroll up or down to the desired picture
10. Press Insert, by pressing the left soft key
11. Press Send To, by pressing the right soft key
12. Press the Navigation Key, and scroll down to desired contact, and Press the Center Select Key
13. Press Send, by pressing the right soft key
You can find this, and other helpful stuff at
this page on the Motorola Support site
Don't forget to rate this solution once you've tried it !
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
