Bag change indicater staying on and vacuum smells hot when using
I suspect there is a blockage somewhere along the pipes leading to the dust bag.
The bag full or bag change indicator measures how strong a vacuum is present at or near to the point where the bag is connected to the pipes. Under normal conditions an empty bag poses little resistance to the air passing through and therefore causes only a slight vacuum. A full bag poses a lot of resistance and therefore causes a strong vacuum which in turn makes the indicator show time to change.
If, however, there is a blockage somewhere, regardless of the state of the bag, a strong vacuum develops which causes the indicator to show as if the bag is full.
The hot smell is proably a result of the motor having to work hard trying to overcome the blockage.
Try to look into all the pipes - you may need to do a bit of dismantling and/or strech out flexible pipes to do so - to see if there's anything stuck. Also try some (careful and gentle !) poking through the pipes with something like an un-ravelled wire coat hanger, but take great care when poking through the flexible pipes as these can be ripped and then you'll have a differnt problem !
My electrolux oxygen hygenica wont start. The filter light & the sad face is flashing. My wife scimped out & put the wrong bag in. I have cleaned the filters that I know of, unfortunately I dont have the instructions as we bought it from a garage sale.
I ran over a scatter rug and the vacuum automatically stopped. I changed the bag and checked filters. I just purchased two months ago from a vacuum dealer. It will not start at all ...there is no indication of a reset button. Please advise.
same thins happend to us, just wont start, one month old. No reset button? great spent a ton of money and now what?
I have a canaster type electrolux vacuum that shuts down after it get hot. The canaster light does not come on when it shuts down. If I take the bag out and hold in on the button it appears the problem stops. Is it possible the aftermarket filters are not letting enought air circulate therefore I have an overheating issue?
