Dewalt DW421 5'' orbital sander Logo
A
Anonymous Posted on Oct 30, 2013
MY SANDER HAS STARTED TO LOOSE POWER WHILE IN USE.
2helpful
2answers
How many Types of Power Sander?
Power sanders are really helpful tools that help the sanding job done in fewer minutes but usually takes hours by hand. The amount of effort requires while removing old peeling paint depends upon the type of sanders is used. If you pick a wrong tool, all your effort may go in vain. Different sanding machines have different specific utilities.
more details Category Sanders
Belt sander wont work. Only 4 hours on the sander.
Get immediatly garantee where you bought it from , but only IF you have tried it on a other powerconnector if you are shure you have no problem for example by power from a cable real with an build in protection circuit breaker button between the connectors , it could be that a contact on the stator electric field is loose or powercable too the switch but garantee is the right place before opening it in any case but you have not connect it to a power generator by somebody that you cannot trust that its after use sometimes was adjusted for the right power because its oft the problem by wrong adjustments by using a generator for power else then your armature can be damaged without a burned colour if there was a power failure too high a voltage that you will see absolutely nothing wrong on your armature but its intermittent on some of the collectors measure between the 2 brushes on ohm with sound by measuring with multimeter ? this is a small suggestion of what can happens with powertools on dubious places .
The disc sander on my ryobi belt/disc sander DB4800 is loose and wobbling
Wen is the best disc/belt combo sander. Wen always best for his price. Cheak the link Best Disc Sanders Selection Guide Before You Buy
My porter cable sander starts then stops and now it wont start at all thank you
If it is not the plug in the wall socket being loose, then the most common is the motor contact brushes.
Slows down and looses power intermettently
you need new brushes or clean out the holes they go in so they move freely
Dead. Power is connected, wires are in tact. Just died when I was using it. Is ther an internal reset?
Try to plug something else into the outlet, just to make sure that the breaker didn't trip.
Try to run the sander without a belt. It may be in a bind.
With the sander unplugged, check the motor brushes. Replace if necessary.
If everything above checks out OK, you may have a loose wire.
Regards, --W/D--
2helpful
Sander stops
There can be a few problems. First is your air supply the right pressure and volume for the sander. Check that at the quick connector to the sander itself. Second, if it is cold and moisture is high, ice can get into the sander which will slow it way down. Third, and probably most likely cause, is the sander well oiled and the parts inside clean. Fourth, mechanical issues: the drive motor may be well worn out inside, the bearing that the main shaft for the sander may be worn out & so forth. Hope this helps you, Rick
2helpful
I can't get the sandpaper to stay on the pad.
It sounds like you need to replace the backing pad on the sander. Over time the velcro (hook & Loop) on the backing pad will loose its stick. A Bosch service cneter can supply you with a new one, just let them know which model you have. If its an adhesive back sanding pad the same thing applys just get a new one. Hope this helps
2answers
Air Sander Guide
# Ensure that sanding belts are not too tight or too loose. Never operate a sanding disk if the paper is loose. # Use the correct grade of abrasive material for the job. # Ensure that the distance between a circular sander and the edge of the table is not greater than 1/4 inch. # Do not push materials against sanders with excessive force. # Sand only on the downstroke side of a disk sander. # Do not hold small pieces by hand. Use a jig for pieces that are difficult to hold securely
Safety guidelines
Top Dewalt Tools & Hardware - Others Experts
john h
Sean Wright
Sean Wright
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
