www.repairclinic.com/...-/KitchenAid-Refrigerator-not-defrosting-KFFS... Show all parts for model KFFS20EYMS00 ... If the defrost heater assembly has burned out, the frost will build up on the coils and eventually no air will be able to ...
you might need to replace the bottom section and spare parts should be available readily online. I had a slow leak on my samsung side by side and it was resolved once i bought a new part...Hope this is of some use but not an expert.....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
the fan only runs when the compressor runs . are the coils clean. and if fan was bad maybe it was running all the time . run time is controled by the min pc control. .it may have to be replaced it is located in the back on the left side under the plate cover .. mm hope this helped .
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
check to see if you have gas in the oil from a carb leaking down which will cause the idle speed to drop when motor warms up.pick up idle run for awhile then plugs foul.like you said a carby problem.
hmmmm no thats peculiar it will slow down and start back each time the doors are open also fan will turn on even if fridge is turned off if a door is opened londer than 3 mins. If the fan still operates irradicly even in the liner protect mode (turn refrig off open door for 3 mins, fan turns on) then the main board is faulty not uncommon for these refrigs.
