Question edited for clarity and spelling, 'hillux' to 'Hilux'..
Question moved to model category.
The Engine Check Light only comes on to tell you there is an issue. Then you connect a Code Reader to the OBD Port and look at the Diagnostic Trouble Code (DTC). The Code is a number and tells you the issue, and from there you can Google the Fix.
If the light comes on and goes off, the fault is transient. The ECM checks data multiple times a second, it can flag an issue and then clear it. The only way to find the code is to have a scanner connected as you drive, and read the Code when it appears.
They can tell how long it has been since the codes were cleared,so you won't get away with it.If it is a code that will stay off for a day,by the least expensive or most likely part that will fix the code,and show the receipt to the emission test station.(Who knows,you might even get lucky and actually fix the issue).
The Check Engine light is most likely an emissions issue, not necessarily a malfunction that will disable the car.
Go to Auto Zone, Advanced Auto Parts, or other retail auto parts store and have them read the OBD codes for you. They will tell the story.
Good luck !
By the way, fix the easiest / cheapest codes to clear first, if there is more than one error code displayed - often the additional codes will clear up too.
The code clearing happens via two things> first, resolve the issue causing the error code. The code will come back if you do not resolve the issue. you can clear the codes by using a code reader, but it woudl likely reappear. Fix the issue causing the error code.
Remember, the code is a clue, not always the issue.
Fix the issue of why it kicking the code. Dont just erase it otherwise your not fixing anything. When you clear the code it erases the info in the pcm so it acts like nothing is wrong until you drive it around a bit and the vehicle re-detects the issue. If you want tell me the code and I will tell you how to fix it.
Normally
this error comes when you are sending any mail having some
attachment.Sometimes when you send an attachment to somebody by Gmail,
it will
occur an error named 008, this is caused by the size of your attachment,
it must be not larger than 25MB, now I will tell you about how to fix
Gmail Error 008.
Symptoms:
While signing in or using Gmail, you receive this error: Oops... (error code ###)
Cause:
A conflict with software on your computer, browser cache that needs to be cleared, or a temporary problem on the Gmail server.
Solution:
Follow the instructions below in the order provided. If they don't
resolve your issue, you'll have a chance to report the problem to Gmail.
Which 'Oops...' error code are you receiving?
007
008
009
102
103
500
602
6413
Other code
If you see this error when sending an attachment, the
attachment may be too large. Please make sure you're sending an
attachment less than 20 megabytes (MB) in size.
If you've confirmed that the attachment is less than 20MB, follow the troubleshooting steps below to resolve the issue.
Please select any security applications you have installed for further instructions.
BellSouth Internet Security//Here i selected this one
eTrust EZ Firewall
Freedom Privacy and Security
Kerio
McAfee
Norton
Proxomitron
Telus
ZoneAlarm Pro
None of the above
Please disable your BellSouth Popup Blocker by following these steps:
Click Start from your system tray and select Run...
Type cmd and click Okay
Type cd c:Program Files//BellSouth/BellSouth Internet Security and press Enter.
Type regsvr32.exe/u pkr.dll and press Enter
If the above steps didn't resolve the issue, you can see if a browser
extension or toolbar may be causing the problem. Browser extensions and
toolbars are intended to enhance browser functionality, but they can
interfere with Gmail.
Please select any extensions you have installed for further instructions.
Better Gmail
Firebug
None of the above
The Better Gmail browser extension may interfere with Gmail. If you are experiencing problems, please upgrade to Better Gmail 2
If you're still experiencing problems, clearing your browser's cache
and cookies can resolve many issues in Gmail. Select your browser below
for instructions.
What browser do you use?
Google Chrome//Here i selected this one
Firefox
Internet Explorer
Safari
None of the above
In Google Chrome for Windows and Linux:
Click the Tools menu tools menu.
Select Options.
Select the Under the Hood tab.
Select Clear browsing data.
Select the "Clear browsing history" checkbox
Use the "Clear data from this period" menu to select the amount of data you want to delete.
Click Clear browsing data.
In Google Chrome for Macs:
Select Chrome > Clear Browsing Data on the menu bar.
Select the "Clear browsing history" checkbox.
Click Clear Browsing data.
Did this fix the problem?
Yes//Here i selected this one
No
We're glad to hear your problem has been resolved. Return to Gmail
Normally
it will
Gmail Error 008.
Symptoms:
Cause:
Solution:
007
008
009
102
103
500
602
6413
Other code
eTrust EZ Firewall
Kerio
McAfee
Norton
Proxomitron
Telus
ZoneAlarm Pro
None of the above
Better Gmail
Firebug
None of the above
for instructions.
Firefox
Internet Explorer
Safari
None of the above
Select Options.
No
We're glad to hear your problem has been resolved. Return to Gmail.
Normally
it will
Gmail Error 008.
Symptoms:
Cause:
Solution:
007
008
009
102
103
500
602
6413
Other code
eTrust EZ Firewall
Kerio
McAfee
Norton
Proxomitron
Telus
ZoneAlarm Pro
None of the above
Better Gmail
Firebug
None of the above
for instructions.
Firefox
Internet Explorer
Safari
None of the above
Select Options.
No
