Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
