HP LaserJet P2055d Printer Logo
M
Matt Silen Posted on Oct 30, 2013
Print tray 2
I cannot get my printer to use tray 2 as the default. It always goes to manual feed.
  • Pete Fotheringham Mar 05, 2014
    the tray settings can be adjusted by openingthe driver window ( control panel- my printers ) use the tabs at the top look for 'Paper' under this tab you can set which is default, what the default paper size is, whether the printer adjusts the print size to fit paper and even low/high toner/ economode levels - hope this helps,
Mario3
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 56 Answers
  • Posted on Nov 18, 2013
Mario3
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
56
Questions
0
Helped
66621
Points
59
Check the troubleshooter for your specific model and see if it can help: http://downloadfreemanuals.com/category/hewlett-packard-manuals/
5 Related Answers
Anonymous
  • 432 Answers
  • Posted on Apr 13, 2009
SOURCE: HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Anonymous
  • 4 Answers
  • Posted on Sep 18, 2009
SOURCE: HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Kenneth Brilliant
  • 39 Answers
  • Posted on Feb 19, 2010
SOURCE: HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Anonymous
  • 1751 Answers
  • Posted on May 01, 2010
SOURCE: Hi, my laserjet 4650 asks which tray I want to
change paper tray from printer properties in you pc
Anonymous
  • 38 Answers
  • Posted on Jun 16, 2010
SOURCE: My printer wont allow us to print from trays 2 or
check the paper menu for tray 1 setting, it should be set to cassette. then make sure the paper size and type for trays 2 & 3 are set correctly.
Why my HP LJ 4100 is always taking envelopes from tray 1, even when I try to print from tray 2?
Check your feed rollers in tray 2. Sounds like they are worn and the paper cannot be pulled from tray 2 so it goes to tray 1
Mfc 7860dw will not print from paper tray
Check the paper level in tray 1 and keep the paper within the levels indicated by the arrows on the side. I had this same problem, and although the paper tray accommodates the extra paper, the printer obviously does not like it and defaults to the manual feed.
2answers
Every time when printing there is a message MANUAL FEED, load paper and click continue
Please check your printer driver to see if the default tray is tray 2 or other than the manual feed tray and take the paper out of the manual tray.
1helpful
1helpful
3answers
HP 1700cp - Can only print with Rear Manual Feed and Not Tray 1
does the printer pickup the paper from tray 1?
if not check the roller, it may time for replacement.
2- make sure the computer program is set at autofeed as default.
or tray 1 as default.
HP Laserjet 5000dn
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Selecting a default paper source for a specific program
That what you want is not TRAY 2 it is Manual feed!! That is need to select to be default or you can empty Tray1 and feed Tray2 and select feed automatic! This both solution will work you choose witch appropriate to you!!!
good luck
Info print 1140
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
k24674
Grand Canyon Tech
Grand Canyon Tech
