They threw away the box with the instructions and we are now being told it's batteries are low and we can't get the thing to open anywhere to find the batteries. Help!
I had a similar problem with my battery going dead in my Logitech mouse. There was a "aa" battery located under the rear top cover. it's the part that has the Logitech logo on it. You simply press the button underneath the mouse @ the back that has a LOCK symbol on it & lift off the cover. Put in a new battery & you should be good to go.
Fred
On some models you simply push down and back on the top rear cover where the Logitech logo is and it will slide off to reveal the AA batteries
I have a logitech wireless mouse and it is not working, how do I access the battery or is there a battery, the red light is flashing and I can't use the mouse at all.
The only clue on my mouse was three fine lines slightly prominent on the mouse moulding directly above the Logitech logo - this proved to be an arcane instruction to press the logo and slide the entire upper rear part of the mouse off the base - revealing a apir of standard AA batteries - job done
My mouse has a little button on the bottom with a "lock" symbol on it. Press this and the battery chamber opens. My mouse takes a AA battery. Don't know the model.
As of 9-20-09 Depending on the model of your mouse, on the bottom there is a button next to the battery symbol all you need to do is press this button and the top bottom portion the with the logitech name on it should lift off to revile battery department.
I tried to follow sandkeyfred's advice, but maybe mine is a different model. The most prominent number on the bottom is CE0560, so maybe that's the model number on my Logitech wireless mouse. It may be that I just didn't follow fred's instructions, but I found two AA batteries in the compartment. To find batteries - press down on the Logitech logo that looks like a crescent moon on left and the sun on the right. At same time, slide the larger COVER (don't try anything on the underside - the batteries are accessed from the top of the mouse) backward and voila!
Hi AN other solution could be that your receptacle that you place your mouse into to recharge our mouse could be faulty and not sending enough charge to your mouse try a new set of batteries in the receptacle and if this fails i would sagest that you buy a new mouse one that has it`s batteries stored in the base of the mouse Hope this Helps Paddy
I have a logitech laser mouse but cannot find the instructions on how to change the battery - I can't locate it. I need to change the battery but cannot open the mouse itself. Help!
What is the model # of the mouse. It should be on the bottom of the mouse. Also most of the time entry, for batteries are on the bottom of the mouse.
after doing a bit more research on your question, I saw that your mouse has a lithium battery. You shouldn't HAVE to change that. Thats why you can't find a door latch. My guess is the mouse won't charge well enough for you to use it for any reasonable amount of time. Have you tried cleaning the contacts on the mouse and the base? you will need a rubber pencil eraser to do that. Just "erase" all four of the contacts. hard but not too hard...that is a pretty expensive mouse.
I have a problem! my cordless mouse doesn't open i guesss. No! i am just dumb. when i press the buttom that has the battery sign. nothing comes up! I NEED DETAILED INFO
This problem was solved in less than 30 seconds
Solution #8 - Stu_Wade! Thank you! Thank you! Thank you! I have the Logitech Optical Mouse C-UM34 and the when I plugged it into my new computer the computer indicated that it detected the device and that it was 'ready for use' but it wouldn't work. Then I noticed the red light on the mouse was on. I ended up using an old corded mouse, then got the optical mouse out again a few mos later and the red light wasn't on anymore (it was just dead!). After much googling, I realized that the batteries were dead. (I didn't even realize the thing had batteries!) I bought the mouse used, with no packaging or manual, so I couldn't figure out where the batteries are! After much more googling, I came across this site and your post. You mentioned the 3 tiny lines just above the Logitech logo, and how to slide that cover off, and lo and behold, I did it, and it came off very easily and the batteries were right there! So thank you! I know this is an old thread, but hopefully someone else will see it and not rush out to buy a new mouse because they think there's is toast. I replaced the batteries and it works great now. Thanks again!
How do I open my Logitech mouse to replace the batteries?
I recently changed the batteries in the Logitech mouse MX700 because I could not charge the battery, but the red light won't go away.
I have pressed the buttons on both the charger and mouse to possibly charge a low battery. Initially the light turns to green, then red then goes off. When I try to use the mouse, the red light again starts flashing.
What is the problem?
THANK YOU! AFTER YOU TELLING ME THAT I LOOKED ON THE PERSONS DESK WHO IS GETTING THIS COMPUTER AND NOTICED A CRADDLE FOR CHARGING THE MOUSE.
Although it will void the manufacturer's waranty; if you need to change the li-ion battery generally you will have to unscrew the mouse piece by piece to get to the batter housing. Just make sure you match the replacement batter correctly. However try everything else first as it can be easy to ruin a potentially good mouse by deconstructing it. Also be sure to follow state, local and federal guidlines when disposing of the old LI batt. This is not a deffinate, but it worked for me.
On my mouse an mx laser bluetooth thingie, I had to uncover screw ports and then actually had to drill (with a small dremel) to get the last screw underneath some translucent plastic.
Good Luck
Proceed at your own risk.
how to change battery
How do I change batteries in my new Logitech cordless mouse?
dont know where the bateries are located for the cordless mouse
MY Mouse has stopped working. There must be batteries, but I can't locate any place to access them. As to the Model number, it is not there, or it is printed so small that I am unable to read it. I purchased it in 2004. It is 2.4GHz - approved in Canada. Hope you can help.
I can't get the mouse open to change the batteries. [email protected]
My cordless mouse no longer works. I took it an electronic store (Wall*Mark) and no one there was able to help me. One suggested that I recharge the batteries but could not find where the batteries were located.
Please help me trouble shoot. Thanks
I can't find where to change the batteries. The trouble shooter says it's on the bottom of the mouse.
cannot find where to load batteries on logitech wireless mouse
cannot find how to change the battery
Cannot find where batteries go on logitech EX110 cordless mouse.
Any help out there?
Barry
How do you open the mouse to change the battery?
It tells me that my batteries are low and now my mouse wont work. I dont know how to change the batteries and now cant use my computer properly. How do I change the batteries??
how to replace battery on Logitech wireless mouse
I can't find where the batteries are in my cordless mouse. My computer keeps popping up saying 'Your wireless mouse batteries are low' and I don't know where they are.. Help? I've clicked the help button on the thing when you go over the batteries in the corner and asked it where the batteries were, but it didn't help.
can't figure out how to get the mouse apart to change the battery
How do you get the battery out of a logitech cordless mouse?
How do I open the mouse to get at the battery?
My Cordless Mouse Receiver is no longer working, and I can't open it to check for batteries - I didn't even know it used batteries. The batteries on the mouse itself are ok. Co. Roscommon
Logitech cordless mouse Model0560
My logitech mouse is not working(stopping ,not moving,turning into curser,disappearing off page can't get it back on etc. I just changed the batteries and its still doing it.
HOW DO I CHANGE THE BATTERY
I can't open the mouse to put in new batteries
logitech dzl-m-rce95 how do I get to batteries?
can't find where the battery is ... red light is blinking
can not open to replace batteries,
How do you access the battery?
dont know where the batteries are
cant cgange battery
mouse is dead how do I change the battery?
older model but cant find where the batterys go
cant find battery to replace it
how opne mouse to replace battery
I dont know where to change the batteries for my mouse
I can't open my c-bs35 mouse to change the battery(ies).
do not know how to replace battery
Need to know how to locate and replace batteries in Logitech Wireless Mouse
Earlier this morning, the mouse was working fine. I figure the battery has been in use for four months. But of course, there are no instructions with this mouse re: how to change the batteries or even open up the mouse. Mine is the cordless mini-mouse that matches the Dell XPS 1530 laptops.
same here
I cannot figure out how to open the mouse to find/replace the battery which seems to be low.
I can't figure out how to change the batteries in my logitech wireless mouse. Help.
