Onkyo TX-SR307 A/V Receiver Logo
Sal Dali Posted on Oct 30, 2013
My fisher ca-9025 stays on standby power need to shut it off.
Seems impossible to find an owners manual for Fisher CA-9025 Integrat4ed Stereo Amp been trying for a couple of days,
I searched and only saw Service Manuals as you stated. Not sure what information you need.
I saw several youtube videos that might give you contacts to email for assistance. I also saw what appear to be the same model for sale on ebay so you might also try emailing vendors as well.
Example: https://www.youtube.com/watch?v=iUv1Y5e9cl0
When it comes to vintage equipment, manuals are hard to find as paper gets trashed and the companies that are no longer in business don't have web sites - not sure how you could get documents that you want without luck. That seems to be a model that is still being used from the web discussions I saw, so maybe consider posting or contacting blogs that have it mentioned.
FIXYA is a free service where answers are provided for free by users just like you, so if you have success with your question or know the answer to someone else's, please post it.
Regards.
1helpful
2answers
Hopefully someone can help...been trying for days. Need owners manual for Fisher CA-9025 Amp. Tom Chichester said Google... but that only brings results for service manuals.
First off you dont look or try to e-mail when you go to their sites HELP NUMBER +1 833 272 0777they have contact info also some have manuals that can be downloaded from their sites also their are 100s of sites with manual if you did a search
1helpful
I have a fisher ca-9145 stuck in standby and have no remote. I used it for years without one but am stuck with standby now... Any help would be awesome
Try disconnecting the speakers and powering up the unit. If it powers up normally there may be an issue with your speakers. When most amplifiers first power up they perform a check on the speakers making sure there isn't a short or a blown driver. If a fault is detected the system will stay in standby or not power up at all. Some more sophisticated amplifiers will display what the problem is.
I suspect in your case however there may be an internal fault needing the service of a skilled technician. The cost of repair of such a fault may be more then the price of a new unit.
-Good luck.
2answers
When i got the fisher home stereo ca-9025 very little sound
Lets try the simple stuff first. Check to be sure that the tape monitor switch is not engaged. Since youare getting some sound, it appears that the signal path is being interrupted. It is possible that the output transistors have failed (open), but that is extremely rare. Check the tape monitor switch and update this with your results.
Thanks,
Dan
Fisher Stereo Intergrated Amplifier CA 9025 is stuck on standby
just bought a ca-275 that i cant seen to get any sound to come out of. but im also testing it with car speakers. is this my culprit
Fisher ca 9025 amplifier
The amp is in protect mode. Something in the final stage is defective. This is usually caused by shorted output transistors. This unit is worth getting repaired. Expect a parts cost in the $25-$50 range.
Dan
50helpful
5answers
For those who accidently put thier CA-9025 in standby mode by hitting the timer button and no longer have the remote, I figured out how to turn them back on.
Turn on the power button and press and hold the Tuner button for at least 10 seconds. it should come back on :) Hope that helps.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
