Question about Health & Beauty
Hi i have a sterling elite xs and the steering loose when i turn it it moves but the wheels dont how do i tighten it please
    Filmmaker:
    Uploaded 5 video answers.
  • 168 Answers
Check underneath and check that all the bolts are in place and done up
Posted on Dec 05, 2013
5 Suggested Answers
SOURCE:
bunnydawg
  • 5158 Answers
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Posted on Sep 08, 2009
Testimonial: "thanks for the answer so quick il phone them tomorrow"
  • 25 Answers
SOURCE: info neede for mobility scooter
http://www.scootamart.com/mobility/mobility-scooters/heavy-duty-8mph-mobility-scooters/sterling-elite-xs-4-mobility-scooter.html
Posted on Oct 02, 2009
Testimonial: "I had given up hope after mailing several company's asking for the number for the scooter, which was met with no answer, then this morning I cam to mai"
  • 23 Answers
SOURCE: would like a owners manual for a sterling Elite XS
I couldnt find the 3 wheel version, but the four wheel is in pdf at
http://www.scootamart.com/media/manual/elite-xs-4-mobility-scooter.pdf
hope this helps
Posted on May 06, 2010
Testimonial: "thanks not the exact model but will be of great help"
wcdoc1953
  • 280 Answers
SOURCE: HI. MyGO,Chair has a problem
Sounds like you have a bad differential in your transaxle. This item is covered under the Pride limited warranty for 3 years. This is not an adjustable item. It is required that you remove the brake motor transaxle assembly, replace the transaxle, then re-install the brake/motor/transaxle.
Labor from a certified dealer is about 1.5 hours. Contact the dealer you purchase it from for service. Hope this helps.
Posted on Mar 20, 2011
Tightening steering wheel on husqvarna tractor 42in 15 horsepower no. yth1542
Interesting! The steering gear can commonly become loose at a several points. I would check the steering wheel itself, prise off the central plastic cover and make sure the nut underneath is tight. Check the gear at the bottom of the steering wheel shaft, if this gets loose it can jump the gear teeth. Sometimes this is so bad the steering wheel will turn without moving the wheels. Tighten everything and replace any worn parts.
Jun 13, 2016 | Husqvarna Garden
My steering wheel on Merc C280 1995 model. While driving I can move the steering wheel slightly left to right, but the car remains straight. Then the car will veere right and then left slightly without me...
Check steering wheel nut is tight, sometimes it may run loose. If it is tighten to specs and is still happening, splines may be worn on steering wheel.
Mar 04, 2015 | Cars & Trucks
Loose steering column
You would need a book and the necessary tools to remove the steering wheel. There are bolts in the upper column yoke that probably need to be tightened up.
You can look for videos on youtube that talk about replacing the turn signal switch which also requires removing the steering wheel.
Feb 11, 2014 | 1992 Chevrolet G20
Steering coluum is moving up and down
it has either come loose inside which is tightenable by removing steering wheel and tightening the screws or it has come loose on the outside which also our tightenable by taken off the cover
Dec 07, 2013 | 1996 Ford Bronco
It starts to swerve to the left or right without turning the wheels almost like your swerving back and forth
sounds as though you have play in steering gear box- most of the time thier is a lock nut on top with a slotted screw in middle loosen lock nut and tighten screw then reset lock nut. do not over tighten slotted screw in fact tighten and then back off half turn so steering box is not too tight.
Jan 26, 2011 | 1981 Ford F 150
My .a.b.s... is on, trac control isnt working, stablity control service light is on, and when im driving i can turn the wheel to 9 o'clock left andtiers dont move. when i reverse it locks my wheels up?...
This is a dangerous problem, dont worry about the abs or trac lite till you get the steering fixed..... Could be a loose steering rack ...when you move the steering wheel that much and the tires dont move you have a serious problem..PLEASE DO NOT DRIVE until you can have someone look under the car it should be vey very easy to see whats wrong Good luck
Aug 26, 2010 | 2005 Pontiac Grand Prix
Sloppy steering 96 Ford Bronco
You need to check all of you front steering components have someone turn the steering wheel back and forth. While you lay on the ground check all joints and components for play then check your steering shaft under the hood see how far steering wheel moves to each directions to when your tires start to move your gearbox has an adjustment on it that can be adjusted it looks like a screw with a nut at the bottom loosen nut a few turns and hold it with a wrench then take screwdriver and turn screw about 1/4 keep checking wheel for play you can tighten to much so keep checking that wheel turns back when you let go if you have any loose joints undernieth replace that part
Jun 22, 2009 | 1996 Ford Bronco
Steering loose
at the end of the steering wheel there is your steering gear box on the top of the gearbox in the middle you will see a screw and a nut you need a wrench to lossen the nut and a screwdriveer to tighten it up. maybe your front end is loose you should have that checked out
Dec 04, 2008 | 1998 GMC Suburban
Health & Beauty Logo
50 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
