SOURCE: mitsumi floppy drive read issue
Then unfortunately your drive is faulty. Have you tried spraying a little compressed air inside to shake around the dust? Otherwise if you are without warranty then you will either have to get a new drive, OR, start using USB thumbdrives which are a lot more economical these days.
SOURCE: external floppy drive does not work on this pc, states it's missing code37
Try unplugging computer power cable for 10 minutes, if computer is a laptop also remove battery for 10 mins, so to cut power to computer, this will solve problems caused by electrostatic charges on computer usb.
If it still does not work, than it means that windows drivers for usb are not working properly, in this case you will have to reinstall the system.
SOURCE: drivers for floppy disk drive mitsumi d359me
I guess the problem is that it does not work? Go to goodwill and buy another or purchase and external USB-Floppy.
SOURCE: Brand new Mitsumi internal floppy drive not recognized by Windows
Check the BOIS setup. Press on boot and see it the Floppy drive is turned on.
