SOURCE: Hotpoint WF430 lights flashing will not start
Hi, the problem is the pump is blocked. What you have to do if your a bit handy is to turn off the power from the plug socket, pull out the machine and take off the back panel, then when you look iside you will see a big black rubber fitting at the base of the mashine attached to a white plastic pump and inturn to your outlet pipe. you have to disconnect the big black one from the top, there is a metal clip which you have to unscrew and it will fall down. inside this is a plastic ball and something which looks like a shuttle ****, take this out and clean everything, you will be suprised what is in there (especially if you have kids) lastly put everything back together and put on a quick rinse cycle. all is fixed! OR Call an repair man, who may try to con you into new parts when they are not neccesary.
SOURCE: door will not open on hotpoint wd420 washing
Turn off the power and isolate the water supply, Move the machine in to the middle of a room - you need some space. If you then rock the washing machine backwards, there is a door release. It's extremely hard to reach, about level with the lock, so make sure the machine is both stable and that someone is with you to ensure the machine doesn't fall and crush you to death!
It basically looks like an little electronic panel, in the middle of which you can see a steel knoble. Press with some force, and the catch will release.
This just happened to ours, and the actual lock is broken, so that was why we couldn't open the door. Yours might have a similar fault. The mechanism is partially plastic and it looks like the plastic sheared off and then the electric release no longer pulls the catch in to the position where it will release.
SOURCE: washing machine door wont open on hotpoint
remove the front kick strip, on the LHS you will notice a yellow tag. with the power on on the machine pull down twice gently on this tab. this should unlock the door.
if you now notice the drum is full of water its more than likely your filter is blocked and this is what caused the door not to open.
