Question about Karbonn K9
I connect charger the message come charging stopped due hardware problem
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 29 Answers
That message appears for one of any number of reasons.
1) over-voltage (faulty charger)
2) under-voltage (faulty charger)
3) temperature (faulty phone / battery)
4) voltage regulation (faulty phone)
The best way to diagnose further is to try a different charger, and battery - I hope you have a friend who has the same phone as you!
Best of luck.
Posted on Oct 30, 2013
SOURCE:
Tablet cont start
It can be due to following reason
1) Virus issues
2) less free space
3) Android/Windows OS issues
3) Due to recent software installation
4) Hardware issues
Try resetting the device, if there is option for pin hole reset
If you battery is removable try removing it and charge it fully for 2-3 hours, or try operating it with charger on (may be battery issue)
If you able to switch it on, do a software reset or remove all recently installed application and free some space in memory
Jul 26, 2014 | Archos 7 HOME TABLET V2 8 GB Hard Drive
Charger or USB connection not recognized by phone
unless your USB wire is not in a good condition or faulty i would say most likely your phone USB socket is very dirty or damaged partly, i would recommend replacing it.
Sep 22, 2017 | Samsung Galaxy S GTI9000 Smartphone
I have an iPhone 4. It has always worked fine, then two days ago, it stopped accepting my charger (the one that came with the phone). When I plug it in to my computer or the wall jack, it charges for about...
have you tried a different charger? and when you restored the phone did you restore it as new? if your still within a year of getting the phone you could try ringing apple they will help you out if your are it may be hardware problem with it and if your in warranty and they determine it to be a hardware issue you get free repair! if you need anymore help just message back :)
Feb 05, 2011 | Apple iPhone Smartphone
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Jan 24, 2011 | HP G60-230US Notebook
After charger is inserted , charging lights come on and battery indicater shows that is charging . After some time , an hour or so , a charging error message appears and says to stop charging . I purchased...
this problem was relating to your phones charging ic to solve this problem please change the charging IC WITH THE HELP OF A HARDWARE MECHANIC
Oct 22, 2010 | Cell Phones
My Nokia N70 doesn't charge.
Either your charger port has got damaged due to moisture or your charger is not working properly. Go to the Nearest nokia care centre (service centre). They will solve your problem in seconds.
Jul 12, 2009 | Nokia N70 Smartphone
When i m charging.. it pops up a message saying that charging error, don charge.. wat's the problem?? my phone is w910i
Hi xue,
This problem occurs due to fault in your charger, The some problem came for me once...
  • try replacing the charger with the ORGINAL Sony charger
Note:Don't use a charger that was manufactured by anyone but Sony Ericsson
Enjoy ! Rate
Vinod Kumar Jayarajan
Jul 01, 2009 | Sony Ericsson W910 Cellular Phone
Problem with wii fit rechargeable battery pack
make sure the battery charger is connected, and that the port connections are tight, other than that I would say you have a faulty charger.
Feb 06, 2009 | Nintendo Fit Battery Pack for Wii
Not charjig properly
its due to the battery terminal short lik. it means tht a small ic wil be thr of charging in ur phone . whn u connect and disconnect hardly ur charger..it wil be gone by short circuit.. as we c in switch board. get it repaired in any hardware shop.. its a hardware probz nt software.
Dec 18, 2008 | Nokia N70 Cellular Phone
Karbonn K9 Logo
50 people viewed this question
Top Karbonn Cell Phones Experts
boca
Level 1 Expert
nelson crespo
ray gallant
ray gallant
Are you a Karbonn Cell Phone Expert? Answer questions, earn points and help others
