Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
Posted on Apr 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E4 error after attempting to fill and get to temp
Hobart LX18H Dishwasher attempts to run normally and goes thru fill steps and then displays an E4 error
Anonymous
Level 2:
  • Expert 170 Answers
  • Posted on May 19, 2009
Anonymous
Expert
Level 2:
Answers
170
Questions
0
Helped
132551
Points
576
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Hobart error code f20
F20 only appears on Washing machines.
E2 error code on Hobart dishwasher E0, E2, E3 & E4 - This appears if the machine isn't filling or filling high enough. When any of these codes display, the unit won't run. Check out our troubleshooting guide for possible causes.Jul. 17, 2019
Hobart Dishwasher Error Codes ' Parts Town
1helpful
Hi i am getting a P1 error on a HOBART AM15 ELECTRIC DISHWASHER
Most likely sump temperature probe needs replacing.
1helpful
Hobart lx18h fills heats water runs cycle but does not get dishes clean
Hi, there is a build up of junk and mold behind the filter screen and under the cover at the bottom of the dishwasher where you will also find standing water that was not draining.
Clean it up and your dishes will come out clean..
Jun 28, 2011 • Dishwashers
7helpful
3answers
Programming LX18H for TRUE FILL AND DRAIN
The LX18 series was a compromise machine, the lack of a sump heater causes numerous rinse temperature problems due to it's increased water use (over the sump-heater equipped, fresh water rinse LX30 series).
The LX18H can be reprogrammed for true fill and dump operation. If you still need to do this, please let me know via e-mail or post a reply, otherwise a won't post the long answer!
(I worked for Hobart as a service tech. from 1994 until 1999, and have been independent since then)
2answers
Hobart LX15H indicates E4 and will not fill.
This is what I found in the manual...and on a couple of other sites....
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
Hobart LX18 E4 Error. Where can I get a manual?
this is asensor error unit not filling fast enough or loose connection
Hobart lxih
E4 indicates water level has not reached top water sensor. Check for proper flow-water pressure to machine (15-25psi) and clean sensor in wash tank
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
