Garden Logo
A
Anonymous Posted on Oct 30, 2013
I need a manual on how to disassemble Stanley riveter mc77.
1 Related Answer
Anonymous
  • Posted on Jan 13, 2010
SOURCE: Stanley MR99 Riveter I dissasembled to release a
How do I dismantle the spiral from the outer casing of a yankee screwdriver
Stanley Bostitch electric stapler model 02010 disassembly
Question moved from Larry's Computer Forum to Bostitch Staplers.
Have a read of the manual, but in general terms, these are not repairable. These days screws are often hidden under the rubber feet, but a new trends is to save on screws and build plastic catches into the case itself. They need a 'spudger' to press around the seam of the case and find where the catches are.
https://manualzz.com/doc/23446217/bostitch-office-02210-electric-and-battery-operated-stapler...
1helpful
Stanley tr-70 spring has no tension
It sounded good but made no sense. How do you remove the trigger/ squeeze handle assembly? This thing (Stanley TR70) is riveted together. The only piece that is removable is the staple feed tray.
4helpful
How to change ball joints on 1994 chevy blazer
Changing the actual ball joints themselves is pretty easy (the replacements just bolt in), however disassembling everything else is very involved, especially if you have a 4x4. Some of the original equipment ball joints are riveted in, so you may need to drill out the rivets to remove the old ball joints. Some models have ball joints that are pressed in. (Your model should not be pressed in. They are either riveted or bolted if they have been replaced already) This is not a job I would recommend to someone who does not know how to do it. You need to disassemble/take tension off the suspension, disassemble the steering knuckles, etc. There are specialized tools you will need as well such as a pickle fork for breaking the knuckle away from the ball joint/A arm, spring compressor or torsion bar removal tool (depending on what your vehicle is equipped with), torque wrench, etc.
If you are set on tackling it anway, do yourself a favor and go to your local auto parts store and pick up a repair manual for your Blazer. It will have the procedure to step you through it, torque specs, and tool part numbers listed in it.
2helpful
Riveter doesn't eject the pin after rivet is seated.
If your pop riveter is the same as mine, after you install a rivet you must turn the tool over and spread the arms and the stem from the old rivet will drop out. I had one stem stick inside the tool, and had to disassemble the whole thing...if you have to do this, have a friend with you...you need 4 hands.
Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Top Stanley Garden Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Stan Ford
Are you a Stanley Garden Expert? Answer questions, earn points and help others
