turn off at wall check the internals of the printer are clear unplug and plug back into computer then restart printer if the printer is working properly clear printer que do a test print
if no better uninstall and reload the printer drivers and any updates on the computer
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
Kernel is a mediator between hardware components(ex:CPU) and software components(ex: OS). So we can bet the problem comes from the driver or software provided for the printer. So you can update the firmware by download the new driver and install it.
Re-install the print drivers, ensuring you use the most current ones for your operating system. Shut off the printer, wait 10 secs and plug it back in. Should work fine for you.
Error 601 takes place when the system is misconfigured or its essential
files are missing. Such problems occur when a PC is not maintained
properly and has accumulated many critical issues that require
immediate repair.<br /><br />solution<br />To repair Error 601 correctly, download and install the repair tool
below. This tool was design to successfully diagnose, find and fix the
problems on your computer.<br /><a href="http://www.restoreguard.com/p/download/go2.php">http://www.restoreguard.com/p/download/go2.php</a><br /><br />hope that was helpfull<br />
