Yes, sounds like the battery is low. need to recharge or replace. An auto parts store can test it for you.
Batteries are usually good for 5 years.
Prior to that then the battery may not be getting fully charged.
Either due to weakening alternator or loose/corroded connections in the big cables, or loose or broken wires.
SOURCE: 96 taurus wagon interior lights and power windows
just a guess but Id look for a bad chasis ground. I say this cuz the interior light switch for the door is a normally- open - grounding. The test for this theory would be to run a jumper wire from the neg batt terminal to the body, or from the eng to the body/chasis.
SOURCE: clicking sound under the dash of my 2001 ford expedtion
sounds like the relay for the door locks is flying south try replacing that relay
SOURCE: 2008 ford fusion: dash lights go dark, but return
MOST LIKELY A BAD BATTERY, TRY TO JUMP START IT . IF IT STARTS RIGHT UP REPLACE BATTERY OR TAKE IT TO SHOP, MOST SHOPS WILL TEST BATTERYS FOR FREE.
SOURCE: How do I take off
You have two terminals on the battery. They have one bolt a piece. The hot side is red. The ground is blue. Make sure the two do not touch. Take the hot side off first. Be careful not to touch the wrench to anything metal. It will give you a shock. Take the ground off next and pull it out. You probably have a battery holder on it to. It should be just a bolt as well.
