Garden Logo
Posted on Apr 28, 2009
I inherited a Weed Eater 1500 gas yard timmer. In
I inherited a Weed Eater 1500 gas yard timmer. In trying to start it the fuel line is deteriorated and needs to be replaced. the problem is, I don't kow where it goes. It was crubled so I can't trace it inside the casing. I have removed the casing and still can not figure out where it goes. Is there a schematic or something to show me where to put it? HELP, I don't want my husband to find out that I have it apart and still can't figure it out. Thanks Geema
  • dzarzour May 13, 2009
    I hav a Weed Eater 1500 gas yard timmer. the fuel line is deteriorated and needs to be replaced. the problem is, I don't kow where it goes. It was crubled so I can't trace it inside the casing. Is there a schematic or something to show me where to put it? HELP, Thanks
  • Jim Parker
    Jim Parker May 11, 2010
    Do you still need help with your trimmer?
    Jim
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
558
Points
You must remove the whole casing and also the 4 screws holding the choke to replace the fuel line on the 1500 you will see a niple near the bottom of the carb
Neil
Anonymous
Level 1:
  • Contributor 50 Answers
  • Posted on Oct 16, 2009
Anonymous
Contributor
Level 1:
Answers
50
Questions
0
Helped
17172
Points
74
Well there should be the prime bubble well screw it if you can call me i can help. 706-354-3867 my name is callie
1helpful
Weed Eater GTI 17T fuel lines diagram and routing please.
Question edited for clarity.
Question moved from Cars and Trucks category.
Check out the videos and also click on the images tab
https://www.google.com/search?q=Weed+eater+GTI+17T+fuel+line+diagram
This if for a Craftsman Weed trimmer
SOLVED: Craftsman 25cc Gas Line Trimmer dies when giving - Fixya
www.fixya.com/support/t5186018-craftsman_25cc_gas_line_trimmer_dies
1 answer
Nov 11, 2017 - Drain the old fuel and make sure the fuel filter is attached to the fuel hose ... SeaFoam or a product called Start will sometimes clean the ... Craftsman gas 25cc weedwacker starts, runs a few secs, then dies. The gas take up line is disconnected or is broken. ... You should be fine for next season that way. I have a Troybilt TB10CS trimmer that starts and ...
Oct 20, 2012
Craftsman 29cc dies when depressing throttle
Aug 27, 2012
SOLVED: My craftsman p2 weed eater won't stay ...
Aug 6, 2012
SOLVED: Weed eater bogs down when i try to give ...
Sep 15, 2010
More results from www.fixya.com
1helpful
2answers
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50
    www.youtube.com/watch?v=uFN82KDj3a8
    Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
Sep 16, 2015 • Echo Garden
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
ON OF THE GAS LINE BROKEN INSIDE TANK.. IT **** AIR.. HOW DO I KNOW WHERE IT GOES..
Try the SEARCH feature on this site. MANY posts have been made about fuel line routing for this and other models (tey are basically all the same). Search for : Weed Eater Fuel Line or Weed Eater Fuel Line Routing. It is there because I have been there and seen it.
1helpful
2answers
Weedeater starts but cuts off when in full throtter
Check fuel lines and primer bulb for cracks or deteriorating.. The new fuels are eating this stuff up. 9 out of 10 times it is not the limiter adjustments.
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
4helpful
2answers
Weed Eater Lightweight 1500 Leaf Blower Fuel Line Repair. There is something in my gas tank, which I assume is a filter of some sort and I need help getting one replaced and onto which fuel line it should...
there are two lines going into the tank one is short which just goes in the for pressure from the primer bulb the other line goes to the filter which goes to the carburator
Itsman
Top Garden Experts
Jay Finke
Jay Finke
john h
