Haier 45-Pint Dehumidifier Logo
N
NEMANI Posted on Oct 29, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A RIVA COLD UNIT IT IS WORKING FINE NUT DISPLAYS E2 ERROR COMPRESSOR MODEL CAJ95132
ernesto cuadra
Level 3:
Top Expert:
  • Haier Master 12,223 Answers
  • Posted on Oct 30, 2013
ernesto cuadra
Haier Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080089
Points
34431
Reset the system read your owner manual section troubleshooting or download from www.retrevo.com or www. manualslib.com
God bless you
Have Danby dehumidifier, turned on first time this season,fan & all displays worked fine, but compressor never went on. Removed back panel & compressor is very hot.
Be careful. i do not know. set at highest setting and let it run. while running, reduce setting to the lowest over a few minutes. at a lower setting you should be able to tell that the compressor has started. run it for 5 minutes, then
unplug your machine. next, feel the cooling coils to see if they are very cold. if they are not cold, your unit needs to be serviced.
1helpful
I have a Kenmore 48 pt. dehumidifier Model#: 5548 (106-855481). It sounds as if the compressor cycles on fine; however, the water pan remains bone dry without a drop of water or moisture in the pan. The...
Do the coils get cold and the unit blow cold air? If not, the compressor is not really working.
Please rate 4 stars if this is helpful. Thanks and good luck!
1helpful
Quit running and displays E2 in the F/C window.
E2 error indicates that the air intake filter needs to be removed and cleaned. Turn the Master ON/OFF Switch to OFF and unplug the unit, before removing the filter. If you wash the filter, it must be completely dry, before reinstalling it. DO NOT run the dehumidifier without the clean filter installed.
Hope this helped you to solve the problem. Please let me know. Thanks.
2answers
I have a new DE45EK unit that has an error code E2. I powered it down for one hour and the code does not clear. First what is this code as it isn't listed in the guide that came with the product. ...
After turning the Master ON/OFF Switch to OFF, unplug the unit for the wall outlet and wait 12 -15 minutes. Then plug the unit back in to the wall outlet and turn the Master ON/OFF Switch to ON. That 12 - 15 minute timeout, should have allowed the unit to reset it self and clear that unknown code.
Since you are not having success using Haier's Customer Support Number, here's their email address
[email protected] <[email protected]>
Hope this helped you solve the problem.
3answers
Dehumidifer will not turn on. An E2 code comes up on the panel. Has been working fine for 4 day.
Since it has been working well for 4 days, it may be a case that the unit needs to reset itself. To accomplish this, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, that timeout allowed the unit to reset itself. Also, check to make sure that the water collection bucket is installed properly and is making good contact with the safety switch.
Hope this helps you solve the problem.
3helpful
3answers
Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
9helpful
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
2answers
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
