I am unable to connect and service provider name is not displayed.Only showing emergency calls.I tried all options
There are 2 likely causes:
1. You got a phone with a dodgy aerial circuit. Go somewhere that normally you got a really strong signal on your old phone and double-check. I just sent a KA08 mini-iclone back because of this problem. It could only connect under perfect conditions.
2. Are you sure the IMEI of the phone you bought is valid? Enter *#06# in your phone, write down the 15 digit IMEI number and check it matches one of the numbers in the battery compartment. Either way, that number may be blocked by your carrier. In Australia, you can check if you IMEI is blocked or not at http://www.amta.org.au/pages/amta/Check.the.Status.of.your.Handset
In other countries you may need to contact your mobile carrier.
