Christian, simply put ... the lower the percentage the more moisture it will extract. The higher the percentage the less it will extract and just maintain that level.
The lowest level is what you want to use in a wet basement. If the ambient air temperature at floor level is between 40 & 60 degrees F, you want to get the dehumidifier up off the floor on to something sturdy, that can handle the weight and the vibration. The reason for this, is that most dehumidifiers will not work well at or between those temperatures. Once the water collection bucket is FULL, the Bucket Full light will come on the the dehumidifier will shut OFF. The bucket most be emptied and properly reinstalled, before the unit will turn ON again. Also, rather than run it in continual mode, run it in a timed mode. Usually either 2 hours of 4 hours.
It seems you don't have the Owner's Manual for this unit. It would be wise to get one. Since it's a Sears Kenmore, you can get it online from Sears Parts Direct. This will help you in the future in performing routine maintenance on the unit.
In the meantime, I hope I helped you understand some of the basic operation of your dehumidifier. Please let me know. Thanks.
Although, this was a poorly designed unit, manufactured by Whirlpool for Sears's Kenmore line, I'm not aware of any recalls due to a defective sensor. I can tell you, that although the air temp in your basement may be 61 degrees F, at floor level the temperature can be as much as 5 to 8 degrees colder. This definitely, would affect the operation of the dehumidifier. Also, a dirty or clogged air intake filter will cause the unit to freeze up. As will dirty condenser coils. Cleaning the coils twice a year, is recommended routine maintenance. And regular cleaning of the air intake filter is a must.
What I would suggest, is that you perform the maintenance mentioned above and move the unit upstairs where it warmer and run the unit there for several hours. If it collects water there, with the humidity extraction level set at 35%, then you will know the unit works as it should and that it needed the routine maintenance and the warmer air temperature. Do not perform any maintenance until the unit has completely thawed and the unit is unplugged from the wall outlet.
Hope this helps you to troubleshoot and solve the problem.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Hi, There can be many reasons why a dehumidifier willnot work or collect water.
Hi, There are many reasons for a dehumidifier to not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
2. The water is not being routed to the collection bucket properly. This dehumidifier has an option to connect to a hose that can be routed to a drain. Look in the back of the unit to see if you see a connection that could accomidate a garden hose. If you see this and there is no hose connected you may be dumping the water on the floor instead of the bucket. This could explain why your carpets are damp.
your coils are probably frosted up. This can happen from the basement temperature being too cold if you dont have the automatic defrost type of dehumidifier, or it could be low on coolant from a pinhole that leaked it out. Mine did the same thing and I had to buy another one. I bought one thats operates down to 41 degrees Fahrenheit and it is an automatic defrost type. It works good for my basement because I have central air which makes the basement even cooler and harder to dehumidify without freezing the dehumidifier up.
