I think just looking at the scope you have on the weapon.
if i was you i would go to gun customizing shop and talk to a gun smith, or someone that does trigger work, with all these gun coempition shooting, here is some info
www.ask.com/
www.infolinks.com/
www.wikipedia.org/
www.searchfiles.org/
www.thesearchenginelist.com/
www.alltheinternet.com/
/gun trigger customizing
/trigger customizing for mfg.name
/gunsmiths customizing triggers
/upgrading triggers for mfg.name
www.youtube.com/refiles/trigger/upgrades
/mfg.name/trigger/upgrades
/do it yourself trigger adjustments
/trigger jobs
Yes but be very careful as there is no spares available
Search beeman rs1 trigger lightening
SOURCE: I'm looking for a factory manual for a Beeman air
Contact Beeman via one of the methods available at the following link:
http://www.beeman.com/contactus.htm
and let them know what you're looking for. Most all gun manufacturers will provide a free manual for anything they've manufactured. It's a safety thing.
Take care!
SOURCE: Where do I find a owners mamual for a Beeman
My problem was that I was looking for a owners manual for my Beeman sportsman 1000 series,so I ended writting to Beeman.
Thank you for the offer,but I will not need your help,if I do need it ,I know where to ask ,thank you again,Dave.
SOURCE: What are the functions for the three screws in the
The larger screw controls the pull weight, that is how many pounds weight on the trigger.
The front smaller screw controls the length of the first stage, whether you want a short first stage or a longer one.
The rear small screw controls the lenght of the second stage which can be reduced to zero.
SOURCE: I have a beeman rs1 chinease air rifle is the
Yes they are adjustable, both 1st and 2nd stage and also trigger weight.
The trigger group is easily disassebled and honed with fine emery paper. You really dont need a mirror surface but the factory surface is very far from smooth. There are som sharp corners on the sear and the trigger lever, DO NOT ROUND THEM.
Pay close attention to the three small springs inside, if you get them mixed up the rifle will not lock.
This work will make all the difference in your rifle.
Just work slowly and with caution not to change the angles in the trigger geometry, all you want to do is polish the surface.
Tutorial can be found here http://webpages.charter.net/guru1/documents/RSE%20Airguns%20-%20Beeman%20RS2%20trigger%20guide.pdf
