Samsung LN40A550 LCD TV Logo
R
Roy Wimberly Posted on Oct 29, 2013
Power light keeps flashing on my samsung 40 inch tv won't turn on
Baker TV Repair
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 57 Answers
  • Posted on Apr 17, 2014
Baker TV Repair
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
57
Questions
0
Helped
7841
Points
62
Either a bad smps or main pcb. Is it a slow flash or only flashing when remote is pressed.
5 Related Answers
vinhson65
  • 257 Answers
  • Posted on Aug 18, 2009
SOURCE: wont turn on
The power supply board has been defected. Replace it with a new one.
roety
Eric Rotmil
  • 587 Answers
  • Posted on Aug 27, 2009
SOURCE: my samsung lnt 4042 40
Hi welcome to Fixya,
The ticking is from the TV not starting properly you should hear the tone noise . here is the solution:
It could be just a few bad capacitors on the power supply, if you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on to.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
with the back removed you will usually see two circuit boards the upper one is the power supply, it has a few capacitors on it (cylindrical standing straight up soldered in mark on the sides with the positive/negative sides and MF and Volts values)
Samsung uses mostly 1000Mfd at 35Volts rating capacitors, they cost about $1 each (680mfd will also work fine)
usually I replace about four of them (or all the bulged on top ones) .
The power board and back unscrew with a medium philips screwdriver, if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
hope this helps
thanks for using Fixya
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Anonymous
  • 927 Answers
  • Posted on Jan 02, 2010
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Anonymous
  • Posted on Jan 30, 2010
SOURCE: 3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
dick davis
  • 610 Answers
  • Posted on Apr 02, 2010
SOURCE: Hi, My SAMSUNG LE40R88BDX/XEU LCD 40
It sounds like the power supply board has some bad capacitors that need to be replaced. Samsung is covering the cost to repair this problem on some models. You can call 1-800-samsung to find out if your unit is covered.
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
1helpful
4answers
Samsung 40" lcd ln40c530f1fxza won't turn on
The main board would be susoect next if the power supply has already been replaced.
Model code HLR4667WX/XAA won't turn on just clicks
Sounds like you have defective capacitors in the power supply board, cheap and easy fix for those with electronics repair skills
Tv won't come on
The set is in Shutdown---27 inch may not be worth the cost of repair
My 40" Samsung LE400B651T is Only just out of the manufactures warranty and is playing up ! The screen / back light goes out after a few hours & will only come back on is the power is removed for about...
Hi liam, this is a common problem and quite easy to fix.
Unfortunately Samsung decided to use inferior generic power boards with their sets. They pretty much use the same power supply for the 32, 37 and 40 inch TV's. This is a great idea for production, unfortunately the power supply fails on the 40 and 42 inch models because of load. I find these power boards pretty cheap on Ebay and replacing them is a breeze. Just keep an eye out for the refurbished boards, since these have been beefed up a bit to compensate for the extra power drain.
My how-to is located here for LCD TV repair:
http://www.fixya.com/support/r4489343-flat_panel_television_repair_yourself
Our flat samsung 40 inch just clinks won;t come on
REPLACE 3 -4 CAPACITORS IN THE POWER SUPPLY, THEY ARE SWOLLEN UP OR LEAKY
6helpful
2answers
My tv keeps clicking and won,t turn on
It is very possible that the power supply may have gone out. Which unfortunately is common on many newer tv's and other appliances. You can use a multi-tester or voltage tester to see if there is any power coming out of the power supply.
Howdy,
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
