Question about Just Wireless Bluetooth Headset - BT-38
Attach phone I do not have access to my Bluetooth instructions and I need to know how to set up my Bluetooth to my Nokia 520 ..
    New Friend:
Starting with the earpiece off, then you have to hold the on-button on the earpiece for a little longer until it flashes red & blue - this puts it in pairing mode. Then go to your phone bluetooth settings & select to discover device. Now it should be able to find it.
Posted on Dec 28, 2013
  • 86 Answers
Hi there. first switch on the bluetooth of your phone . then switch on the on button of your bluetooth device and keep it pressed for few seconds till the time the power lightgets on and now in your phone go to the option search new device .once ur phone detects the bt 38 name get it paired and it will start working
Posted on Oct 29, 2013
SOURCE:
Why can i not receive or send picture mail
you need to have MMS settings in order to do so.
Same can be provided by your service provider, as it would really depend on who provides you your services..
If you know who your service provider is, you can probably find manual configuration settings/steps on the web using the search term: "Nokia Lumia 520+MMS setting+<name of your service provider>"
Here's the settings for Vodafone:
Nokia Lumia 520
Mar 01, 2015 | Nokia Lumia 520 Windows Phone Black
Nokia lumia 520 unlock pin required
Hello. To which network has your Nokia Lumia 520 been locked to.? You can get the unique unlock code for a Nokia Lumia 520 from Unlock-Zone.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia Lumia 520 without any sim card.
2 - Don't bother as to what is displayed on your Nokia Lumia 520.
3 - Compose #pw+CODE+1#.
4 - The Nokia Lumia 520 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia Lumia 520 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia Lumia 520
SOURCE: MobileUnlockGuide.com
Nov 11, 2014 | Cell Phones
How to get unlock code for nokia lumia 520,imei :351737060551944
Hi. You can get the accurate unlock code for your network locked Nokia Lumia 520 either from the respective network provider or from trusted online vendors like MobileUnlockSolutions.com at affordable cost.
Jul 29, 2014 | Nokia Lumia 520 Windows Phone Black
How to unlock a phone. Nokia lumia 520
Hi. You can unlock a Nokia Lumia 520 safer and easier using unlock code. You can get the accurate unlock code for your Nokia Lumia 520 either from your respective network provider or from any trusted vendor online like TheUnlockArena.com at affordable cost.
Jul 17, 2014 | Nokia Lumia 520 Windows Phone Black
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
Images transferred via bluetooth not accessible or locateable.
I have seen a feature in older phones that you can see files received via bluetooth in settings>bluetooth>received files
Jun 23, 2017 | Nokia Lumia 520 Windows Phone Black
Unlock nokia 520
I suggest you can approach Mobileunlocksolutions.com and specify the country,locked network of your Nokia Lumia 520.Based on the availability you can get the unlcok code along with free instructions.
Nov 27, 2013 | Nokia Lumia 520 Smartphone - Wireless LAN...
Cannot pair my nokia N6730c with plantronics voyager 520
You want to remember that newer phones are like small computers, so
they may become corrupt over time and you may need to reset them every
so often. Simply turn your phone off and remove again the battery for
a few seconds, then replace the battery and turn it back
on again. Then carefully follow the pairing instructions in the attached link.
Plantronics Voyager 520 User's Guide
Good luck from Headsets Direct!
May 29, 2011 | Plantronics Hama Voyager 520 Bluetooth...
Just Wireless Bluetooth Headset - BT-38 Logo
187 people viewed this question
Top Just Wireless Radio Communications Experts
Marvin
Marvin
robert
Don Eagan
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
